headers hitting one driveway
Old Apr 17, 2013 | 09:12 AM
cutlassclay's Avatar
I put headers on my cultass last summer and now i cant park it in my driveway due to the ride height of them.. (my driveway has a slope to it)...i need around 3.5 to 4 inches of lift in order for my headers to not hit..i have replaced the rear springs before the headers but it still needs more..what should i do? i dont know much about suspension. please hep me
Old Apr 17, 2013 | 09:13 AM
headers hitting on driveway**
Old Apr 17, 2013 | 09:22 AM
What brand header are you running?
Old Apr 17, 2013 | 09:44 AM
flowmaster, they are tucked up tight.. and fit perfect in the groove in the frame
Old Apr 17, 2013 | 10:03 AM
Do you have a SBO or BBO, any front end mods, front springs sagging? Do you have a picture of the underside of the car showing clearance.
Old Apr 17, 2013 | 10:16 AM
Rocket331's Avatar
I'd move.
Old Apr 17, 2013 | 10:20 AM
droptopron's Avatar
delete
A pic of the car & the driveway would help
Old Apr 17, 2013 | 10:46 AM
ok so i have no mods done but im sure that the front springs are sagging...ill put up pics as soon as i can (few days)...and i am moving in a few months but i need a quick cheep fix...i was thinking new front springs with coil spacers on both front and rear
Old Apr 17, 2013 | 10:57 AM
Sbo
Old Apr 17, 2013 | 11:33 AM
BAAAAD idea. The car will look like a 4x4 and handle like one as well. For a "cheep" fix, get chickens, but for a CHEAP fix, buy some 2x12s to lay on the ground where you drive the car up the driveway.
Old Apr 17, 2013 | 11:50 AM
455man's Avatar
What size are your front tires?
Old Apr 17, 2013 | 11:51 AM
BackInTheGame's Avatar
I'm gathering parts to renovate the entire suspension/steering/running gear, etc. of my '68 442. Because: 1)the original springs were sagging to the max and the front have spacers installed by previous owner , 2)I want to run slightly larger tires, 3)will be installing headers when I get to that part of the resto, AND 4)I like the look - I bought new springs, F&R, that are 1 inch taller than stock.
Old Apr 17, 2013 | 12:01 PM
i have stock 14 inchers...good luck with that
Old Apr 17, 2013 | 12:03 PM
455man's Avatar
And what size are the tires? 225/70/14?
Old Apr 17, 2013 | 12:27 PM
yes sir
Old Apr 17, 2013 | 10:16 PM
brownbomber77's Avatar
Well...in my younger years, I did manage to put a set of BBO long tubes on a SBO and they were pretty damned close to the ground. This is a real question because they are hard to distinguish...are you SURE you have SBO headers? BBO are 1 inch lower to the ground than SBO if I am not mistaken. Because the higher deck height, in order to put the collector at the same level as the SBO, the BBO are 1 inch taller from the bottom of the collector to the top of the flange. I like the 2x4 idea the best
Old Apr 18, 2013 | 07:26 AM
I like 2x4 idea also, especially if this is a temporary issue.
Old Apr 18, 2013 | 08:35 AM
coppercutlass's Avatar
Chevy budget Olds powered
My drive way has a steep pitch ad my headers have never hit. i have a set of spare sbo headers i know tuck in tight .
Old May 2, 2013 | 09:39 AM
i went with the 2x4 idea haha it works for now. thanks guys
bob p
Apr 20, 2015 10:56 PM
a64olz
Jan 7, 2013 05:25 PM
70worm
Nov 8, 2012 05:05 AM
2blu442
Dec 14, 2009 04:27 AM
79TASFLA
May 23, 2009 09:15 AM
