A frame bushing. Are they circle or oval?
Old July 1st, 2012, 10:30 AM
Alex72cutty's Avatar
72 cutlass A frame bushing. Are they circle or oval?
I went to the parts store today to get front suspension parts and when it came to the a frame bushing he asked if I had the circle or oval ones. I have no way of telling so I was wondering if you guys can help me out.
Alex72cutty is offline
Old July 1st, 2012, 11:50 AM
rn_mccy's Avatar
Look under car at the lower a arm. The bushing toward the back of car is the one they are talking about. You will be able to look at it to determine if it is round or oval. Mine were oval.
rn_mccy is offline
Old July 1st, 2012, 12:00 PM
DENT's Avatar
The lower A arm rear bushing is oval on my 72 and the 70 olds parts car I had.
DENT is offline
Old July 1st, 2012, 12:46 PM
Your car is 72. So unless someone has swapped out the control arms they will be oval.
Allan R is offline
Old July 1st, 2012, 01:07 PM
Run to Rund's Avatar
According the the Olds parts book, the change to oval was made early in the 1969 model year.
Run to Rund is offline
Old July 1st, 2012, 03:15 PM
Ok, I dont have the car so I'm going to going with oval. I'll keep you guys posted. Thanks!!
Old July 1st, 2012, 03:21 PM
MOTORHEAD
11971four4two's Avatar
I would buy both the round and the oval ones. That way you you will have the "right ones" when you need them , regardless which style your car happens to have. Then return the unused parts to the store when the project is finished
11971four4two is offline
Old July 1st, 2012, 03:29 PM
Sounds even better!! Thanks!!
Old July 1st, 2012, 06:07 PM
Lady72nRob71's Avatar
Just crawl under that car with a flashlight and you will be able to see if it is oval or round. I did it easily.
Lady72nRob71 is offline
Old July 1st, 2012, 07:39 PM
That's cause you're way more skinny than me...
Actually an easier way is just look at the Assembly Manual or CSM for the car. It's pretty well spelled out in pictures there. see pages 100, 102 http://wildaboutcarsonline.com/membe...Sect_2_-_5.pdf
Page 3-21 in the CSM has an excellent pic showing the different size bushings http://wildaboutcarsonline.com/membe...ection_2-3.pdf
Allan R is offline
Old July 1st, 2012, 07:46 PM
Generally, oval was for smoother ride, round was for tighter steering.
Ovals were used on most, if not all Oldsmobile coupes and sedans, round were used on some station wagons, El Caminos, and some high-performance Chebbies (and maybe other makes).
Since the car's been around for a while, what you actually find on it is anyone's guess, but the odds are they will be oval.
MDchanic is offline
442b
Wheels and Tires
July 3rd, 2020 10:02 AM
cutlassefi
November 28th, 2013 12:08 PM
auto_editor
July 10th, 2011 11:20 AM
oldzy
December 5th, 2010 11:48 AM
Nilsson
May 18th, 2009 09:20 AM
Quick Reply: A frame bushing. Are they circle or oval?
