Differential Bushings
Old Jan 7, 2026 | 07:42 PM
Bigdibbs88's Avatar
Hi All- replacing the bushings above the differential on my 67 442 and looking for any tips on reinstalling. The typical C-clap type press with fittings doesn’t fit due to the housing contours so I cut the old ones out, now I’m wondering the best way to get new ones in? Thanks!
Old Jan 7, 2026 | 08:45 PM
I used a piece of pipe and a hammer on rubber stock types and a piece of wood and a hammer on poly with the inserts removed.
Old Jan 8, 2026 | 06:14 AM
Bob Kelso's Avatar
Put the bushings in a freezer for a few days then you should be able to install them with a dead blow hammer
Old Jan 8, 2026 | 09:36 AM
I use an air chisel with the edge ground flat and use that against the bushing lip to drive them in. I clean the bushing bores and put some light lubricant on the surface to reduce friction while installing them.
Old Jan 8, 2026 | 11:16 AM
Bigdibbs88's Avatar
Thanks all! I had hoped freezing and lube would get me there but didn’t want to get stuck half way. Glad to hear that should work
Old Jan 8, 2026 | 12:19 PM
One thing to mention is don’t hammer on the rubber part as that absorbs the energy. You need to contact the metal part of the shell.
don71
Drivetrain/Differentials
Feb 26, 2025 07:40 PM
scrappie
Suspension & Handling
Aug 12, 2019 08:13 AM
frozencaveman
Jun 13, 2018 09:50 AM
Lars
Apr 21, 2013 08:26 PM
oldzy
Oct 8, 2010 06:36 AM
