Control Arm Install - More Initial Camber or Less Initial
Old Jan 7, 2022 | 11:06 AM
sschevellecutlass_Bob's Avatar
Team
About to install Speedtrech Road Assault Suspension kit on 1970 Cutass. Control Arm Instructions have diagram (See attached). Which is better for conservative street driving? MORE initial camber or LESS initial camber Just looking for improved performance and handling under routine driving - occasional exercising the of the horses but mostly in straight away.... not a cornering wild man.
Bob
Old Jan 7, 2022 | 01:03 PM
Neither is correct. Camber should be at factory spec. Unless there was some reason why you couldn't achieve the correct camber setting with the original shaft, there is no reason to use an offset shaft.
More CASTER is desirable to improve steering response and feel. This shaft won't help that one way or the other.
Old Jan 7, 2022 | 01:28 PM
Rallye469's Avatar
Pshhhhhh....no way bro.
-peter​​​​​​​
Old Jan 7, 2022 | 01:34 PM
-peter​​​​​​​
Aw hell. Now you made Mt Dew come out my nose (and it matched the car!).
dennis_30281
Jan 18, 2018 11:24 AM
62 Cutlass Convert
Tech Editor's Desk
Jun 11, 2015 09:15 AM
1969cutlass4d
Jan 6, 2015 11:26 AM
costpenn
Suspension & Handling
18
Apr 20, 2012 03:04 PM
oldzy
Dec 19, 2011 06:43 AM
