Ball joints, a-arm bushings.
Old Jan 10, 2018 | 08:20 PM
1965Jetstar's Avatar
Thinking of tackling too and bottom a-arm rebuild. This will be my first time. My question is do I go for a pre packaged complete set or collect piece by piece? It's insane that 2 moog ball joints can cost nearly as much as a whole rebuild kit.
https://www.ebay.com/i/201402209642?chn=ps&ul_ref=http%253A%252F%252Frove r.ebay.com%252Frover%252F1%252F711-117182-37290-0%252F2%253Fmpre%253Dhttps%25253A%25252F%25252Fwww .ebay.com%25252Fi%25252F201402209642%25253Fchn%252 53Dps%2526itemid%253D201402209642%2526targetid%253 D398677331039%2526device%253Dm%2526adtype%253Dpla% 2526googleloc%253D9033505%2526poi%253D%2526campaig nid%253D1028253084%2526adgroupid%253D54605285710%2 526rlsatarget%253Dpla-398677331039%2526abcId%253D1130036%2526merchantid% 253D6516924%2526gclid%253DEAIaIQobChMIk-KCt4DP2AIVBtVkCh1VfQfnEAQYAiABEgKVwfD_BwE%2526srcr ot%253D711-117182-37290-0%2526rvr_id%253D1413151086220
Old Jan 10, 2018 | 11:31 PM
Charlie Jones's Avatar
Phantom Phixer
Most "kits" are cheesey China made garbage .
NOS GM made parts are the best , when you are lucky enough to find them .
Old USA made , aftermarket parts are next best .
Moog parts come after that . And are acceptable .
I see what you mean , I did a quick search on E-Bay for a Moog K5073 balljoint .
Which is the lower joint for a '65 Jetstar .
Prices ranged from $143.94 (Summit Racing) down to $74.99 (West Coast Parts ) . For the same Moog K5073 ball joint !
On my '63 Dynamic 88 I had several years to gather parts . I shopped E-Bay daily and found all NOS or NORS parts for the front end . And I paid less than I would have from the K***** company .
Old Jan 11, 2018 | 04:32 AM
If they are correct, rockauto has them for $64.89
http://www.rockauto.com/en/parts/moo...ll+joint,10070
Old Jan 11, 2018 | 07:20 AM
Go read my response to your other thread. If you think the Moog lower ball joints are expensive, wait until you try to find the correct, out of production, UPPER ball joints.
Old Jan 11, 2018 | 08:31 AM
just messaged the seller for a compatibility chart. Hope these will do. https://m.ebay.com/itm/1965-1970-OLDSMOBILE-VINTAGE-MOOG-K5150-Ball-Joint-Quality-Made-in-USA-LEFT/332496410559?epid=656455226
Old Jan 11, 2018 | 08:41 AM
Im not sold on moog yet either. Is there an alternate US manufacturer half the cost? I feel like moog is overhyped due to warranties that rarely get used. I'd rather pay half the cost if the replacement timeframe is the same and not deal with warranties.
Old Jan 11, 2018 | 09:31 AM
Sure. Half the cost, half the quality. I've previously cheaped out and had to re-replace ball joints after a couple of years. I don't do that any more.
The ebay upper is a smoking price. Note that the uppers are different RH/LH due to the bolt pattern.
Old Jan 11, 2018 | 10:54 AM
SOB!!! I just logged in to ask if left/right was different part numbers and you already answered. Thanks Joe.
Old Jan 11, 2018 | 11:00 AM
65 cutlass calls for same part number right and left? I am working on a 1965 jetstar 1. I know it's not a cutlass but find it odd that the delta or jetstar would have right/left specific upper ball joints but the cutlass does not?
Old Jan 11, 2018 | 11:49 AM
Phantom Phixer
That's the way it is . Also note that the Jetstar joints fit only Olds . Not any other GM make. The Cutlass joints will fit Chevy , Pontiac , and Buick .
Old Jan 11, 2018 | 11:55 AM
Thank you. Is the 98, Delta, jetstar, the same front end parts for 65? Finding the right parts is harder than the labor.
Old Jan 11, 2018 | 12:39 PM
All 1965-70 Olds full size cars use the same front suspension. Yes, they are not the same as A-body. These cars are not popular to restore, so the market for these parts is small, thus the limited sources and high prices.
Old Jan 11, 2018 | 12:44 PM
Phantom Phixer
The control arm bushings and ball joints are the same on all 65 Olds except F-85 (Cutlass) . I see that the lower control arms use 2 different bushings also , front or rear
None of these parts fit anything other than an Olds , except the lower control arm bushings , which are shared with Chevy .
Old Jan 11, 2018 | 12:49 PM
That's because other than the F-85s, Olds only built full size cars (Eighty Eights and Ninety Eights) in 1965.
From 1966-1972, the only car lines were F-85, Full Size, and Toros.
Old Jan 11, 2018 | 02:37 PM
JOE. I found an old post from a couple years ago where you referenced a complete front end rebuild kit from Kanter. Was this one of your trial and error experiences on your way to only using Moog? Thoughts on TRW?
Old Jan 11, 2018 | 04:56 PM
That post is likely from before the time I got my 67. I have used Kanter for suspension parts for my 62 and was less than impressed.
Moog, TRW, McQuay Norris are all quality brands. Only Moog is currently making parts for these cars. The TRW and McQuay Norris replacement parts do show up as new old stock. FYI, the "T" in TRW is Thompson, which made OEM parts for Olds for these cars. You'll note that the center link, pitman arm, and idler arm can be either Saginaw or Thompson, and the diameter of the tapered stud is different between the two. TRW stands for Thompson-Ramo-Woolridge. Thompson was the car guy, Ramo and Woolridge were the space guys. Combines my hobby and my job.
I interviewed with TRW in Redondo Beach when I graduated college. I seriously considered going to work for them because there was a parts counter in the building where you could get employee pricing on TRW car parts! They even had the parts store paper catalog on the counter.
Old Jan 8, 2019 | 05:02 PM
mpolds's Avatar
I do have (only a few) N.O.S. Left & Right Upper Ball Joints --- and the rest of this Front End --
in U.S.A. made parts -- but as indicated ------ Jetstar I parts are not cheap -- particularly, if you want QUALITY -- and that IS a smart move on this car.....
And don't pay attention to the answer offering Cutlass / Jetstar ball joints --- those are "toys" compared to yours...
Always best to simply call me -- Craig -- 516 - 485 - 1935.... West Hempstead, New York..
Old Jan 24, 2019 | 05:05 PM
mpolds's Avatar
I haven't heard from you in the three weeks since you made your many queries and received some answers that are solid (Joe P's and mine) and others.....
Guess you are busy saving pennies... Because that IS necessary on this front end. -- but if
you can "swing it, monetarily" during this wintertime, I would. be able to give you your maximum discount, while things are slow..
Give me a call when you are ready --- your car will LOVE you....
Craig. 516 - 485 - 1935
Old Feb 9, 2019 | 02:41 PM
mpolds's Avatar
Hello????
You seem to have disappeared...
You're not buried under a tremendous snow bank somewhere, are you????
Let us know if we need to send out an APB.......
costpenn
Sep 20, 2020 02:52 PM
oldsonharmont
Suspension & Handling
Nov 28, 2017 05:16 AM
UMMM NAH
Aug 30, 2017 10:02 AM
borgerding
Dec 3, 2015 04:45 PM
christl
Aug 21, 2012 07:31 AM
