springs
Old Feb 16, 2019 | 10:46 AM
olds330's Avatar
springs
hey guys
good afternoon.....
I have a 67 442 400E and I am putting in tubular A-arms, spindles, swap to disc brakes while I'm in for a buck I
might as well put new springs in.... any recommendations would be great or the right part number for Moog....
not dropping the ride height.... keeping it stock or even up a bit would be fine...
thanks,
John
Old Feb 16, 2019 | 07:57 PM
Run to Rund's Avatar
Moog has never had many offerings in tangential-tangential springs of the correct diameter and length. Never offered the 425 lb/in 4-4-2 coils. You will have to modify something after choosing the spring rate you want.. For example, 5230 coils for 6 cylinders are about 250 lb/in and quite long so the car will sit higher with them, but have a soft suspension. Other coils are for the 330 engine, etc.
Old Feb 17, 2019 | 06:33 AM
jcdynamic88's Avatar
i can't tell you the part # i used but when i put the 455 in my 65 f85 i used 330 with a/c springs from moog.it does sit a little tall which is what i wanted.jc
Old Feb 18, 2019 | 08:36 AM
olds330's Avatar
the 330 with AC are the springs that I put in 20 years ago. was just looking to see if others had done something different .....
thanks for the input
john
Old Feb 18, 2019 | 10:55 AM
BackInTheGame's Avatar
Eaton Detroit Springs
Eaton Detroit Springs, on the web, has an application chart for these. You may select from several sizes shorter than stock, up to several sizes longer than stock, along with spring rate. They hooked me up real quick. I had the springs of my choice in about 10 days.
Good Luck!
Old Feb 18, 2019 | 11:31 AM
olds330's Avatar
great, thanks for the heads up....just looked this up, will get these ordered today... I do have one question, will stock ball joints
and shocks work with one inch taller spring?
Old Feb 18, 2019 | 11:46 AM
My MOOG replacement ball joints have not shown any issues.
Old Feb 18, 2019 | 11:54 AM
olds330's Avatar
great! thanks! no trouble with stock shocks either?
Old Feb 18, 2019 | 12:13 PM
Correct; no shock issues either.
bob provost
Suspension & Handling
Mar 9, 2019 06:19 PM
96powerstroke
May 2, 2017 05:44 PM
olds68442
Aug 9, 2015 03:50 PM
Kid Thunder
May 11, 2015 10:46 PM
64 Cutlass
Sep 15, 2009 10:46 AM
