1972 delta 88 rear springs
Old Nov 12, 2016 | 04:01 AM
72delta88's Avatar
will 1972 vista cruiser rear springs raise the rear on a 72 delta 88 2 door ht I'm sick of messing with the air shocks the p.o put on and the springs are junk
Old Nov 12, 2016 | 04:06 AM
They should, the amount would be based on the difference in load rating of your current springs vs what you put in.
Old Nov 12, 2016 | 04:08 AM
72delta88's Avatar
I'm looking at the heavy duty springs theres about a 2.5 inch difference between the ones on the car and what I want the guy I bought the car from said the rear was sagging so he put air shocks on it
Old Nov 12, 2016 | 05:12 AM
Putting station wagon springs in coupes/sedans has been a tried and proved method of raising the rear of cars for decades. Give them a try just be advised that sometimes it may be more than what you expect.
Old Nov 12, 2016 | 06:24 AM
You will be a happier person in the end if you pony up $100 and buy the correct set of Moog CargoCoils and install them.
The ride will be better, your ride height will be correct, and because of the CargoCoils' shorter uncompressed height, they will be a LOT easier to install.
Old Nov 12, 2016 | 07:24 AM
The ease of installation is not an issue with the rears, the space is very accommodating.
Old Nov 12, 2016 | 07:32 AM
Oh yes it is.
There is no space problem on A-bodies.
On fullsize cars, though, at least on '71-, the rear does not swing up and down far enough to easily accommodate the factory springs, which are thin, with a very long uncompressed height. You need to get in there with prybars and a sledgehammer to get them out, and getting them in is even more fun.
The CargoCoils just drop right in, though, just like the rear springs on an A-body.
- Eirc
Old Nov 12, 2016 | 07:41 AM
x 2
The reason the PO put air shocks in is because the car is 30+ years old and the springs are all worn. Don't go overboard. Do the job 1 time and do it right.
Old Nov 12, 2016 | 09:17 AM
72delta88's Avatar
I'm dropping the rear completely out so putting the springs in shouldn't be to bad I'm gonna change the center section and rebuild the brakes I'm goin from a 3.08 posi to a 3.73 posi
Old Nov 14, 2016 | 05:47 AM
Oh yeah!
Keep us posted on your project.
Old Nov 15, 2016 | 08:52 PM
72delta88's Avatar
Talking
Originally Posted by Olds64
Oh yeah!
will do shes mean as it is
scottmac
Suspension & Handling
Jul 30, 2016 07:47 PM
Gary M
May 15, 2016 02:28 PM
Bobac455
Dec 4, 2013 10:03 AM
bigjaythe1st
May 8, 2012 05:45 PM
1acesmith
Aug 11, 2011 11:03 AM
