Vin Decoder
or
Login with Facebook
Suspension & Handling
1972 Cutlass S Coupe - Front Spring Rate
June 29th, 2012, 07:11 AM
yankees
Does anyone know what the factory front spring rate was for a 1972 Cutlass S Coupe with No AC, Power Steering, 350 2bbl with Auto trans Turbo 350?
yankees
Find More Posts by yankees
June 29th, 2012, 08:14 AM
Lady72nRob71
My magic decoder ring displayed an LZ code 280lb spring, same per side.
Lady72nRob71
Visit Lady72nRob71's homepage!
Find More Posts by Lady72nRob71
June 29th, 2012, 09:22 AM
yankees
Thanks for the info. I actually have new Moroso 47160's going into the front that are rated at 242lbs.
yankees
June 29th, 2012, 09:23 AM
yankees
The signature pic is with 28" Moroso DS2s and stock springs, which sits an inch or 2 too high.
yankees
June 29th, 2012, 10:01 AM
Lady72nRob71
280lb was the lowest rate available on the A bodies in 72. 242 is a bit low, so it will ride smooth but can bottom out easily.
Lady72nRob71
June 29th, 2012, 10:13 AM
Tony72Cutlass'S'
By the way, are springs symettrical? So, does it mattery which side is on the top and the bottom as long as i line it up with the drain hole?
Tony72Cutlass'S'
Find More Posts by Tony72Cutlass'S'
June 29th, 2012, 11:27 AM
Lady72nRob71
Quote:
Originally Posted by
Tony72Cutlass'S'
Closed up side is up. Open side is down.
Lady72nRob71
Front spring rate?
bigmac
November 7th, 2010
12:08 PM
Need high load rate on rear coil springs
Bobac455
July 16th, 2010
07:49 AM
How do 455 GA heads rate?
9teen68/442
April 10th, 2010
06:37 AM
Front spring rate
65oldsf85
January 18th, 2010
02:54 PM
WHAT'S THE GOING RATE? (72 hood)
BosMobile
May 28th, 2009
08:48 PM
Tie rod adjusting sleeve??
Posting Quick Reply - Please Wait
Quick Reply:
The following errors occurred with your submission
Okay
Quote message in reply?
09:52 AM
