1972 Cutlass S Coupe - Front Spring Rate
Old Jun 29, 2012 | 07:11 AM
yankees's Avatar
Does anyone know what the factory front spring rate was for a 1972 Cutlass S Coupe with No AC, Power Steering, 350 2bbl with Auto trans Turbo 350?
Old Jun 29, 2012 | 08:14 AM
Lady72nRob71's Avatar
My magic decoder ring displayed an LZ code 280lb spring, same per side.
Old Jun 29, 2012 | 09:22 AM
yankees's Avatar
Thanks for the info. I actually have new Moroso 47160's going into the front that are rated at 242lbs.
Old Jun 29, 2012 | 09:23 AM
yankees's Avatar
The signature pic is with 28" Moroso DS2s and stock springs, which sits an inch or 2 too high.
Old Jun 29, 2012 | 10:01 AM
280lb was the lowest rate available on the A bodies in 72. 242 is a bit low, so it will ride smooth but can bottom out easily.
Old Jun 29, 2012 | 10:13 AM
Tony72Cutlass'S''s Avatar
By the way, are springs symettrical? So, does it mattery which side is on the top and the bottom as long as i line it up with the drain hole?
Old Jun 29, 2012 | 11:27 AM
Closed up side is up. Open side is down.
bigmac
Nov 7, 2010 12:08 PM
Bobac455
Jul 16, 2010 07:49 AM
9teen68/442
Apr 10, 2010 06:37 AM
65oldsf85
Jan 18, 2010 02:54 PM
BosMobile
May 28, 2009 08:48 PM
