1968 442 tubular control arms or stock ?
Old Sep 29, 2021 | 06:48 AM
jonnyslim63's Avatar
Hi out there. Needing to replace my control arms in the front on 1968 442. Can anyone recommend a tubular set to replace the stock arms ? Does it make it feel more stable ? I replaced my 64 nova front end with tubular and it made a huge difference.
Thanks for any help.
Old Sep 29, 2021 | 09:06 AM
UMI makes quality parts at reasonable prices.
Old Sep 29, 2021 | 03:57 PM
RetroRanger's Avatar
72 Olds CS
The tubular arms usually have more caster built into them. The increased caster helps w with a more pronounced return to center feel.
the older alignment specs for our cars calls for 0 or even negative caster. If you increase caster to as much as you can get w OE control arms (maybe ~+2° is achievable) it will lend a better more stable feel to your steering
(assuming you using modern radial tires)
The tubular arms are (hopefully) more rigid than the stamped OE control arms and w the increased caster built in they should be a good upgrade.
IDK if there is a number thats too much positive caster ? m sure there is but i dont know if its acheivable even w tubular arms ? eric anyone ?
Old Sep 29, 2021 | 08:38 PM
With stock control arms the most caster you can get is around +2. With aftermarket you can get +5-6 sometimes more. If your not autocross type racing or extreme slalom type driving chances are the stock setup will work fine.
Old Sep 30, 2021 | 09:33 AM
72 Olds CS
Ive got OE front uppers and lower CAs. The alignment guy said he got about + 2* on each side so that jibes. The RTC is better and highway tracking is better. I also have the quick ratio steering box which is a nice upgrade to the steering as well.
i looked at the UMI arms they specifically mention increased caster built into their parts.
joesw31
Mar 6, 2021 09:56 AM
Pete Mahar
Ninety-Eight
Aug 22, 2019 04:25 AM
Tjohn8573
Aug 21, 2019 04:07 AM
Tjohn8573
Oct 8, 2018 10:59 AM
rrtracks
Aug 28, 2009 05:07 PM
