1968 olds 98 convertible: rear upper and lower control arms?!?
Old Aug 21, 2019 | 05:50 PM
Pete Mahar's Avatar
I can’t seem to find tubular rear upper and lower control arms. If I understand correctly, this is a GM c body and all I’m seeing is a body arms. Any help is appreciated.
A body lowers fit but the uppers are too short.
btw I don’t want oem because the previous owner ran a custom exhaust that didn’t fit going by the control arms so he shaved the rear uppers🤦*♂️. Not much I can do I already blew one apart figure I should replace both shaved uppers and might as well replace the lowers with tubular arms too
Old Aug 21, 2019 | 06:28 PM
Fix the exhaust and use stock uppers. Not much support for the big girls suspension, hopefully someone might have been there and done that.
Old Aug 22, 2019 | 04:25 AM
The 1965-1970 full size cars use the same rear lower control arms as the 1964-72 A-body cars and the same rear upper control arms as the 1964-67 A-body cars. The aftermarket manufacturers don't list these applications because there is no demand for parts for these cars, but the arms do fit.
74hurstolds
Jul 15, 2014 11:57 AM
501Paratrooper
May 7, 2012 11:25 AM
RAMBOW
Feb 22, 2012 01:51 PM
Doug in SD
Suspension & Handling
Jun 24, 2011 06:25 AM
hamm36
May 23, 2009 09:55 AM
