1964 Cutlass Front Sway Bar upgrade
Old Jul 3, 2022 | 05:11 PM
Sweet64's Avatar
Hello there everyone, quick question here, id like to upgrade my front sway bar from stock oem bar, and i was thinking about buying one, and the bushings & brackets to match the new size of swaybar from the parts place over in Dekalb Illinois, ive had great luck with the company over the years and its fast shipping for me, as im in eastern Iowa. With that said, if i go ahead with the 1 1/4 front sway bar, do i need new swaybar links? Or is it ok to use the new ones that i installed last year to the oem size sway bar. Thanks, appreciate your time everyone, have a great 4th of July weekend, safe travels!
Sweet64
Old Jul 6, 2022 | 10:18 AM
72cuttys's Avatar
the upgraded bar i ordered from UMI came with end links. Not sure that helps much but id call and confirm.
Old Jul 6, 2022 | 01:13 PM
Sweet64's Avatar
Thanks 72Cuttys, i looked at UMI kits just here recently, whats your overall impressions after upgrading your swaybar? What kit # did you go with? Thanks, appreciate your feedback & time.
Sweet64
Old Jul 7, 2022 | 05:24 AM
It depends on which bar you are using. If you are using the 1.25" Trans Am WS6 bar, you need the T/A end links. If this is an aftermarket bar there's no telling which links you need. FYI, I've been buying the T/A bars at swap meets for $25-$50 each, quite a bit less than the aftermarket bars.
Old Jul 7, 2022 | 06:19 AM
Sweet64's Avatar
Thanks Joe, appreciate the feedback as always, thats a steal in price compared to what some of these companies are asking for swaybars, just curious, what year or years should i be looking for in regards to snatching 1.25" Trans Am WS6 sway bar & links. Thanka, appreciate your time. I was looking at that Parts Place front swag bar kit, with shipping prolly a good $175 to get it to the door..
Old Jul 7, 2022 | 06:21 AM
The second gen T/As are the ones you need.
REO442
Sep 5, 2020 01:14 PM
NotDads442
Apr 25, 2018 07:29 AM
1965cutlassragtop
Suspension & Handling
Jan 24, 2013 04:17 PM
78ChevOlds
Sep 27, 2010 10:13 AM
72OKOLDS
Sep 1, 2009 08:03 PM
