Timing Set Install
Old Oct 3, 2011 | 07:47 PM
CutlassDad's Avatar
Timing Set Install
Including my son's (DJS70Cutlass, from this forum) car last fall, the topic of "in the car" timing set installations has come up several times.
The photos illustrate the lifting frame that we fabbed up to allow us to lift the front of the engine with the oil pan front seal area open...the photo of the engine mount shows how far the engine had to be raised for pan r&r clearance.
Old Oct 4, 2011 | 04:54 AM
RetroRanger's Avatar
72 Olds CS
Thanks for posting I have been thinking about this too
Old Oct 4, 2011 | 05:29 AM
DJS70cutlass's Avatar
Originally Posted by CutlassDad
Yeah, this was a sloppy messy job, but well worth doing in the end. No leaks and she run better than it ever has
If you notice in the above pic the chain was so loose that I could have taken it off with no tools. Didnt find ANY nylon in the pan, so I dont know where that went
Old Oct 5, 2011 | 05:18 AM
Destructor's Avatar
How many miles on the engine?
Old Oct 5, 2011 | 06:03 AM
Had 166k when we did this last fall, have put 2k on it so far, no problems. And my next step is to get it cleaned up a bit
The chain was starting to wear into the non nylon coated teeth of the cam gear. The teeth of it are VERY sharp. Really not sure how the chain stayed on seeing as how I put nearly 100 miles on it for a show two months before
Del70
Aug 31, 2014 06:22 PM
s i 442
Jun 20, 2014 10:08 PM
jpc647
Jun 10, 2013 11:48 AM
71RadioflyerVista
Jun 28, 2011 09:11 AM
442scotty
May 13, 2009 05:42 PM
