running a belly pan on aluminum intake?
Old July 22nd, 2010, 01:40 PM
import extermination's Avatar
i have an edelbrock performer intake, and im chaning the intake gasket. should i run a belly pan gasket, or use the felpro intake gaskets
import extermination is offline
Old July 22nd, 2010, 01:55 PM
Usually the stock intake manifold gasket is referred to as a "turkey tray." IMHO, ditch the turkey tray and use an aftermarket gasket. Also ditch the end rails and use RTV instead.
Olds64 is offline
Old July 22nd, 2010, 03:11 PM
perfect! i even have the after market gaskets at home(came in a gasket kit).
Old July 23rd, 2010, 05:41 AM
There are about a zillion posts on our website about intake manifold gaskets. If you have any questions the search function will get you pronto info incase you can't wait for a response. Good luck putting on the intake manifold.
Olds64 is offline
tocicar8825
September 21st, 2021 07:10 AM
88hurstolds
January 20th, 2020 11:39 AM
Carl, uk
March 13th, 2014 05:43 AM
TIM FISKUS
May 12th, 2013 05:17 AM
jensenracing77
August 12th, 2009 08:27 PM
Quick Reply: running a belly pan on aluminum intake?
