mondello headers & my 66 330 Cutlass
Old Apr 24, 2010 | 07:28 PM
scubastever's Avatar
this is not my car lol
they are a tight fit, and it seems like they need just a 1/4" more clearance.
I'm thinking of building a 1/4" plate riser that will bolt between the engine mount pads and the frame.
Or does anyone know of a mount pads with a raised mount hole?
Joe P should if anyone does!
Old Apr 25, 2010 | 04:20 PM
The frame pads for the 64-72 A-body cars come in two flavors. The 69-72 big block cars used one with the cross bolt hole about 2 1/4" down from the top two bolts and all the rest (big and small block) used mounts with the cross bolt about 1.5" down from the top two bolts. You should have the latter in your car, so the answer is no.
Are your motor mounts relatively new? Old mounts can sag and distort, causing the motor to sit a little lower. That might be your 1/4" right there. Use Anchor P/N 2261 mounts with the stock frame mounts.
Old Apr 26, 2010 | 10:34 AM
thanks for your help, Joe..
the mounts are brand new and i used up the adjustment slots on the right mount pad. i still have contact present.
i am going to shim up the mount pads with 1/4" washers and hope this gets the clearance needed.
1964F85
Nov 13, 2019 08:40 PM
aqua67w30
Apr 19, 2015 04:17 PM
bluecab
Jul 16, 2014 07:14 AM
harry k
Nov 21, 2012 08:54 AM
Wyze
Mar 18, 2012 01:59 PM
