build up 350?
Old Jan 3, 2007 | 03:37 PM
ZASX's Avatar
build up 350?
hi,i`ve got a350 rocket w/#7heads and a 4 barrel,what can i do to bump up the hp?
Old Jan 3, 2007 | 08:57 PM
texasred's Avatar
Tom Servo's Stunt Double
1971. I know it well. Since you didn't say, I'm assuming it's street and occasional strip (feel free to correct me if I'm wrong). My recipie:
Improve the breathing-pocket port the heads and open up the air cleaner
Improve heat retention in the intake-have the crossovers in the heads filled and go to a later model electric choke.
Improve compression-1970 pistons are the best
Improve intake-Performer RPM and you can keep the QJet
Improve fuel delivery-have the QJet professionally built (it's cheaper than a new carb and, really, they're great carbs) and a Robb Mc 440 fuel pump
Improve valve movement-roller rockers (not roller tip...ask me how I know) and a good cam (with matched torque converter,of course). I like my Lunati Performer RPM clone cam
Improved ignition-HEI with external coil, MSD 8mm wires and Delco plugs
Improved gearing-I like 3.42s on the street, but I know guys that run 3.73s with no problem
That's my formula...but there's as many opinions as there are drivers.
Or you could just lock and load a 455.
C.J.
Old Jan 7, 2007 | 08:57 AM
ZASX's Avatar
Thanks For The Info
agreen316
Dec 21, 2013 06:27 AM
wildwillie1981
Apr 24, 2013 04:19 PM
J-(Chicago)
Mar 5, 2008 02:07 AM
69 442 protour
Dec 9, 2006 09:25 PM
bigshot846
Nov 22, 2006 07:57 PM
