Exhaust manifold gaskets on a 403?
Old May 29, 2026 | 06:46 PM
MrEarl's Avatar
79 Buick Estate Wagon, 148,000 mile, 403 engine. Noticing an increased exhaust noise in engine bay, can't tell exactly where it's coming from. Hopefully just at the manifold tailpipe connections. Will be taking to a shop but would like to know a bit more than I do such as are there gaskets (donut type or other) at the manifold tailpipe connections?
Old May 29, 2026 | 08:18 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yes on the passenger side rear outlet. Oldsmobile V8's didn't use exhaust manifold gaskets. I seen a few leak working in a garage. We installed a gasket and we never had any return.
Old May 30, 2026 | 03:54 AM
MrEarl's Avatar
Thanks! Since the manifold ends are already shaped conically to fit into the tailpipe, are we talking about a flat fiber type gasket or ? Do you recall what size?
Old Yesterday | 07:44 AM
They were usually blue fiber with a metal ring built into the top. It is basically the shape of the metal cone built into the manifolds on the crossover pipes. Carefully tighten the three bolts by hand and don't go too tight.
Old Yesterday | 11:40 AM
FStanley's Avatar
have had good luck with RemFlex gaskets I cleaned up head and exhaust manifold surfaces as best I could while still attached to the exhaust pipes on the car. I used a flat file covered with 220 grit sandpiper then cleaned it off with brake cleaner and a paper towel. Remflex can deal with a lot of warpage.. 20lbs torque at most..
Old Yesterday | 09:04 PM
MrEarl's Avatar
something like this
Old Today | 05:36 AM
No. The Felpro
60240 was what I always used. That picture is **** on Summit. This is what it looks like.
It could also be rotten bolts on the manifolds and crossover. You will have to narrow it down to where the leak is.
Old Today | 05:50 AM
MrEarl's Avatar
No. The Felpro
Okay, thanks. I just know the shop will likely say 403s don't use gaskets and wanted to have something to suggest if the need arises. My hearing isn't very good these days so am having a hard time determining where the sound of the leak is coming from. I've read of a reverse airflow test where a shop vac is used to blow into the exhaust pipe and soapy water sprayed on the joints. I may try that. Thanks for your help!!!
Old Today | 10:19 AM
That sounds like a good plan. If everything is tight and not rotten, good chance it is one of the two gaskets needed to fix the leak. We had good luck with just slipping in a manifold gasket and leak was gone. Those donuts usually don't leak, unless they are disturbed.
Buick77
Oct 17, 2025 01:01 PM
rpjr42
Dec 19, 2023 07:07 AM
Kennybill
Oct 13, 2013 05:09 PM
RAMBOW
Aug 12, 2009 06:24 AM
toneypenna
May 24, 2009 07:08 PM
