Exhaust manifold gaskets on a 403?
Old May 29, 2026 | 06:46 PM
MrEarl's Avatar
79 Buick Estate Wagon, 148,000 mile, 403 engine. Noticing an increased exhaust noise in engine bay, can't tell exactly where it's coming from. Hopefully just at the manifold tailpipe connections. Will be taking to a shop but would like to know a bit more than I do such as are there gaskets (donut type or other) at the manifold tailpipe connections?
Old May 29, 2026 | 08:18 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yes on the passenger side rear outlet. Oldsmobile V8's didn't use exhaust manifold gaskets. I seen a few leak working in a garage. We installed a gasket and we never had any return.
Old May 30, 2026 | 03:54 AM
MrEarl's Avatar
Thanks! Since the manifold ends are already shaped conically to fit into the tailpipe, are we talking about a flat fiber type gasket or ? Do you recall what size?
Old Yesterday | 07:44 AM
They were usually blue fiber with a metal ring built into the top. It is basically the shape of the metal cone built into the manifolds on the crossover pipes. Carefully tighten the three bolts by hand and don't go too tight.
Old Yesterday | 11:40 AM
FStanley's Avatar
have had good luck with RemFlex gaskets I cleaned up head and exhaust manifold surfaces as best I could while still attached to the exhaust pipes on the car. I used a flat file covered with 220 grit sandpiper then cleaned it off with brake cleaner and a paper towel. Remflex can deal with a lot of warpage.. 20lbs torque at most..
Old Yesterday | 09:04 PM
MrEarl's Avatar
something like this
Buick77
Oct 17, 2025 01:01 PM
rpjr42
Dec 19, 2023 07:07 AM
Kennybill
Oct 13, 2013 05:09 PM
RAMBOW
Aug 12, 2009 06:24 AM
toneypenna
May 24, 2009 07:08 PM
