307 coolant loss?
Old Dec 12, 2006 | 12:01 AM
Redog's Avatar
307 coolant loss?
I don't know exaclty what is happening, but I'll fill my overflow bottle and it will empty after a few days?
The temp is also going sky high, but the car still runs fine. It does drop back down to 195* but after filling the overflow it stayed at 180*
I have a new thermo at home but it's a 180* not a 195* which the car has right now. Guys at work say that it's the rad cap is the wrong PSI rating. The car does have a Be Cool rad, but the stock one did the same thing
Any ideas, I'm
Old Dec 12, 2006 | 01:06 AM
texasred's Avatar
Tom Servo's Stunt Double
It certainly could be the radiator cap rating...or just that it's getting old. The temp spikes make me wonder about the head gasket, too. And while I'm at it, I'll throw in a vote for freeze plugs leaking.
C.J.
Old Dec 12, 2006 | 03:42 PM
Redog's Avatar
There is no coolant in the antifreeze and I'm not leaving a trail of white smoke. There is less steam from the exhaust than the 2007 Jetta rental car we have right now with 800 miles
Old Dec 12, 2006 | 08:09 PM
texasred's Avatar
Try a 50/50 mix of antifreeze (it raises the boiling point). You might not see white smoke...water vapor only appears with a temperature differential and it would be in the heated exhaust stream.
I'll stick with my suggestions.
C.J.
Old Dec 13, 2006 | 06:14 AM
Redog's Avatar
I want to flush out the coolant anyway. I think I put too much water in the bottles when I mixed it
Nop
Jun 28, 2014 05:02 AM
Seff
Feb 4, 2014 11:37 AM
Jonmueller1
Sep 10, 2013 06:48 AM
DeltaDevil88
Jul 15, 2011 09:36 PM
Dutch
Dec 16, 2007 01:39 PM
