1954-55 324 Valve Stem Seals
Can you measure the id and od of the seals you have ? And the valve stem size. Any decent automotive machine shop should be able to figure out which ones you need if you have those dimensions. They look similar to a Chrysler seal but need dimensions to be sure.
I think this is a set of the originals but I would not buy them. They are probably dried up after 70 years
https://www.ebay.com/itm/314829008240
I would measure the valve stem diameter, valve guide diameter and valve spring I.D.. And the approximate length of the valve seals you have. I don't think you can accurately measure a moulded part. . I wouldn't be surprised to find they fit other engines.
Fusick has them, just looking for a part number in something I can just pick up locally at Napa. https://www.fusickautomotiveproducts...?number=VSS514
The Fusick seals look like mine.
