I need some ideas on the best way to attach my throttle and manual choke.
Is there a bracket available for each cable (throttle and choke) that will mount to my Holley 4150?
A complete new throttle cable maybe? I have the original cable and bracket.
The choke does not use a bracket, the cable is cinched down where you have the wire clamped to keep it open. You can try modifying the mount of the original throttle cable bracket to the mount you are using for the return springs.
Edelbrock has some nice brackets also. By the way you will probably have to hook the throttle cable up to the hole on the linkage where you have the return springs going to. Otherwise it is going to be very hard to push the pedal. In my opinion those springs are total overkill. The stock GM double spring is all you need.
