Holley 4BBL model 4150 throttle bracket
Old Oct 8, 2022 | 07:32 AM
lala5818's Avatar
I need some ideas on the best way to attach my throttle and manual choke.
Is there a bracket available for each cable (throttle and choke) that will mount to my Holley 4150?
A complete new throttle cable maybe?
I have the original cable and bracket.
Old Oct 8, 2022 | 08:30 AM
The choke does not use a bracket, the cable is cinched down where you have the wire clamped to keep it open. You can try modifying the mount of the original throttle cable bracket to the mount you are using for the return springs.
Old Oct 8, 2022 | 10:16 AM
tmaleck's Avatar
Holley also has multiple throttle bracket kits. I got the ball stud the fit the factory linkage and the other one for the TVS cable on the 700R4.
Old Oct 9, 2022 | 07:33 PM
BillK's Avatar
Edelbrock has some nice brackets also. By the way you will probably have to hook the throttle cable up to the hole on the linkage where you have the return springs going to. Otherwise it is going to be very hard to push the pedal. In my opinion those springs are total overkill. The stock GM double spring is all you need.
Old Nov 13, 2022 | 06:50 PM
s i 442's Avatar
Oldsmobile enthusiast
Wheres the rest of the bracket for the cable, here is what you need and hook it up like the pic. works great.
Jun 16, 2021 04:34 PM
442crzy
Jun 15, 2018 04:26 PM
1970442
Mar 21, 2012 11:04 AM
stlbluesbrother
Jan 8, 2012 07:20 AM
seok
Mar 15, 2011 10:53 AM
