Oil type and quantity
Old Mar 10, 2022 | 01:10 PM
Monkeyman0398's Avatar
I have a 1969 cutlass S with a 350 rocket, I'm wondering what kind of oil to put in it? Do I need additives? And how much oil?
Old Mar 10, 2022 | 01:16 PM
5 quarts of oil.
Many here like the Valvoline VR1 line of oil as it has the correct additive package for our older engines.
Old Mar 10, 2022 | 02:29 PM
BackInTheGame's Avatar
Welcome aboard, Monkeyman. For additional oil info, Search here on CO. There are a number of threads comparing the different brands and their recipes. You definitely want high zinc content, per the general consensus. I just caught an Amazon sale on (3) 5Quart jugs of the Valvoline VR1 that Fun71 mentioned.
Old Mar 10, 2022 | 03:39 PM
Sugar Bear's Avatar
You didn't ask but use a quality filter, Wix, Baldwin, Mobil1. 5 quarts included replacing the filter.
Have fun and drive on...!!!
Old Mar 10, 2022 | 03:47 PM
5 qts of Valvoline VR1 10w30 and a wix oil filter. No additives needed.
Old Mar 11, 2022 | 07:41 PM
5 quarts of oil.
ok cool thank you!
will do thanks for letting me know!
Old Mar 12, 2022 | 08:58 PM
CANADIANOLDS's Avatar
I only use Lucas hot rod and classic in flat tappet builds. It has 2100ppm zinc content.
Valvoline VR1 has 1400
Old Mar 14, 2022 | 11:53 PM
Ozzie's Avatar
Use the appropriate viscosity for the temperatures in which the engine will operate. Check your manuals.
Old Mar 16, 2022 | 02:38 PM
holidaysedan's Avatar
Brad Penn PennGrade-1 Racing oil "the Green Oil" (originally Kendall Oil) also has high ZDDP (zinc) levels. They provide a minimum of 1500 ppm zinc in all PennGrade 1 oils
Old Mar 16, 2022 | 04:23 PM
Sugar Bear's Avatar
Contacted Shell last week, they advised Rotella T4, T5 and T6 (except for T6 Multi-Vehicle 5W-30) have approximately 1200 PPM ZDDP.
Old Mar 18, 2022 | 08:41 AM
Put me down for Lucas as well, along with a Napa Gold oil filter.
And don't fall victim to the "heavier is better" theory of oil -- 10W-30 or 10W-40 should be plenty, depending on the ambient temperature and conditions where and when you drive. Unless you live near the equator 20W-50 is probably not necessary.
Gary M
Apr 5, 2017 08:05 AM
ART T
Oct 29, 2016 03:16 PM
scooter123
Mar 5, 2014 11:23 AM
Tony72Cutlass'S'
Sep 23, 2012 05:44 AM
