Rear main seal
Old Mar 7, 2022 | 06:13 PM
rfpowerdude's Avatar
Rear main seal
What is the Ford application that has the same size rear main seal for a SBO but is two piece rubber? Putting the 403 back together and the rear main seal and intake gaskets are all that I still need to buy.
I did a search, but couldn't find a thread with a direct answer quickly.
Thanks all!
Old Mar 7, 2022 | 06:22 PM
WannaBa442's Avatar
https://classicoldsmobile.com/forums...n-seal-156207/
Old Mar 7, 2022 | 06:23 PM
And boom. Answer in minutes! Thanks a bunch!
Old Mar 7, 2022 | 07:01 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I used the 292 Ford Y block seal, it goes in easy. I also used the AMC 252 inline 6 seal, supposedly the AMC 360 is the same without the "ears" on it. It is a tighter fit than the 292 seal. Lube is needed to install, most offset the seal from the cap line and use RTV at the seal ends and a little bit in the cap. Here is some links. One actually as an Olds replacement.
https://www.summitracing.com/parts/s...ake/oldsmobile
Ford 292
https://www.summitracing.com/parts/fel-bs6141/make/ford
AMC 6 seal, you can see the extra "ears" that need trimmed.
https://www.summitracing.com/parts/f...0612/make/jeep
Old Mar 7, 2022 | 08:33 PM
Thx brutha, I did this to my ‘83 Hurst like 7 years ago and couldn’t remember!
wabasto
May 23, 2016 08:19 AM
transman74
Sep 20, 2015 10:48 AM
truckerlary
Jun 19, 2015 02:16 AM
Lugardo
Oct 5, 2013 10:17 PM
rcrac3r
Nov 12, 2012 07:39 PM
