69 350 heads need help
Old Mar 31, 2020 | 08:39 AM
pgalioto1's Avatar
On the heads that are mismatched on my 69 cutlass 350. The vehicle sn is 336879M163895. That does not seen to match either of the head # 5A397 742 or # 3A554 716.The block # is 3955582 located top front of block next to oil the tube. I was wondering if I would be able to use one of the heads and get another to match it. If so which one? Thanks
Old Mar 31, 2020 | 10:19 AM
Sugar Bear's Avatar
To precisely and completely answer this,we need the block VIN derivative from the block stamped just below the #1 spark plug on the BLOCK not the head. The number next to the oil fill tube is casting/part type # not the VIN derivative. Matched heads will work and probably the 5A is the best choice but get us the block VIN derivative.
Old Mar 31, 2020 | 09:14 PM
cdrod's Avatar
Rodney
One more time. Head casting number 397-742 is a #5 small block from a '68-'69 350 engine and has 7/16" head bolts. It is NOT a 5A head. A 5A head fits '80-'84 307 engines. The 3A head with casting number 554-716 fits a '77-'79 350 with larger 1/2" head bolts. As SugarBear and others have stated, the VIN derivative number stamped on the block is needed to fully ID your engine.
Old Mar 31, 2020 | 09:54 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
There is a 5A head from that time period, rare but does exist.
Old Apr 1, 2020 | 06:00 AM
pgalioto1's Avatar
Block# 39M440544
Old Apr 1, 2020 | 06:05 AM
lemoldsnut's Avatar
I can do a pair of correct #5 heads for a 68-69
email direct lemoldsnut@aol.com
Larry
Old Apr 1, 2020 | 11:18 AM
cdrod's Avatar
Rodney
pgalioto1:
Your block is a '79 350, it has windowed main journals which are not are strong as the earlier (pre '77 blocks). It also has 1/2" head bolts. If you want to run earlier (pre '77) heads you will need to drill out the bolt holes in the head to fit the 1/2" head bolts. If you already have one '69 #5 head, it's had the bolt holes drilled out to fit the 1/2" bolt holes in the '79 block. You still have a compression ratio mismatch between the earlier #5 head and the later 3A head.
Old Apr 1, 2020 | 12:20 PM
He said the block casting number is 395558 2 which is a 1968-1976 block.
Old Apr 1, 2020 | 12:24 PM
Sugar Bear's Avatar
Isn't a 3955582 casting # 1976 or earlier or is it 77 on up also? To the OP, can you tell the ORIGINAL color of your engine. Look under the block etc.
Old Apr 1, 2020 | 12:42 PM
cdrod's Avatar
Rodney
Guys,
I totally screwed this up. Yes this is a '69 block, please disregard everything I posted earlier about the block. The head info is correct.
Old Apr 1, 2020 | 02:47 PM
Sugar Bear's Avatar
That's good news that it is a '69 block. At least it is the correct year for the car. Now if 5A and 5 heads are identical he just needs one head preferably a 5A if not a 5. Depends on how correct he wants the car.
Old Sep 6, 2020 | 08:25 PM
Ratdog442's Avatar
I have 69 5A heads. Everyone says they are from a 307. I know better.
Old Sep 7, 2020 | 02:54 PM
The difference is the size of the A. On the early engines the A is small, about 1/2 the size of and offset downwards and away from the number/letter. On the later engines the A is the same size as the number.
Here's a pic of 1972 heads with the small A and 1980s 307 head with the large A:
Old Sep 7, 2020 | 03:37 PM
Are the A as small on the 5A vs the 7A heads? I thought I saw pics and they looked more like the later 5A heads as far as lettering.
Old Sep 8, 2020 | 08:53 AM
Ratdog442's Avatar
The A is large not small...the reason I know is because I have the 5A heads with the casting number from 1969. Believe what you see not what you hear.
Old Sep 8, 2020 | 01:43 PM
Agreed. This is a perfect time for you to post some pictures of those heads.
Old Sep 8, 2020 | 01:53 PM
Ratdog442's Avatar
I will. Then a video smoking the tires.
Old Sep 10, 2020 | 08:58 AM
Loucobalt's Avatar
Chiming in due to relevance of post. I too have a numbers matching 350 engine/heads in my '69 Cutlass. Heads have a "5A" on them.
Old Sep 10, 2020 | 12:25 PM
Can you post a pictures?
Old Sep 10, 2020 | 05:12 PM
Ratdog442's Avatar
Old Sep 12, 2020 | 06:27 PM
Smaller than the later 5A heads. Good for 350's in 83 or 84 H/O or an 85 442.
Old Sep 13, 2020 | 07:22 AM
Ratdog442's Avatar
they are 69 heads. not 80;s..I posted the casting number on the heads...the casting number is from 1969.
Old Sep 13, 2020 | 09:55 AM
I realize that, other than die hard Olds guys, no one knows two varieties of 5A heads exist. Put some grease over the block casting number and everyone else will think it is a Vin 9 307 under the hood. I wonder why they changed where the A went on the 72 7A heads?
Old Sep 13, 2020 | 11:00 AM
Ratdog442's Avatar
I guess I can use it to my advantage next time I lift the hood.
pgalioto1
Apr 8, 2020 08:44 AM
76sbo
Mar 5, 2020 10:33 AM
azwildcats
Oct 1, 2019 10:25 AM
lunaboy
Sep 24, 2018 10:15 AM
Cpriester123
Aug 15, 2016 01:52 PM
