J heads to C heads help
Old Feb 27, 2020 | 08:55 AM
76sbo's Avatar
I changed my J heads with C heads. The J heads have a 1 piece fulcrum for the rocker springs and appear to be cast. The C heads have a 3 piece fulcrum and are stamped steel. The stamped version also has washers under the bolts as the 1 piece does not. I am using the same push rods from the J heads with the springs that were on the C heads. Is this common? or is there something more to this. Should I use the J fulcrums with the C heads or the C fulcrums with the C heads? Does it matter? both sets of heads are all stock.
Thanks for any help
Mike
Old Feb 27, 2020 | 09:02 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Aren't the stamped steel, aftermarket replacement? The Sealed Power replacement I bought are what you mentioned but no washers.
Old Feb 27, 2020 | 09:08 AM
76sbo's Avatar
Could be I am not sure.
Old Feb 27, 2020 | 09:14 AM
66SportCoupe's Avatar
Anything 3 piece is aftermarket. They're an improvement over the one piece aluminum ones. Will work with up to around .520 lift cams.
Old Feb 27, 2020 | 09:17 AM
76sbo's Avatar
Excellent, Thank You
Old Feb 29, 2020 | 06:16 PM
Schurkey's Avatar
Last time I tried to save used rocker arm parts, I needed 3+ sets of used parts to scavenge enough "good" stuff to make one functional set.
Used fulcrums are almost guaranteed to be junk.
The aftermarket parts have a better chance of still being good, simply because they PROBABLY have fewer miles on them. Check everything carefully.
Did you have hardened exhaust seats installed, or did you not have a valve job done?
Old Mar 1, 2020 | 03:07 PM
VinMichael's Avatar
Have you driven it yet after the swap? What’s the power difference?
Old Mar 1, 2020 | 05:28 PM
oldolds88's Avatar
65 66 a and b heads had factory 3 piece. actually more,two rockers,two copper washers,2 rectangle shape pivots, two nuts,and two studs. still haven't learned to post pics or I could show them.
Old Mar 5, 2020 | 10:32 AM
76sbo's Avatar
No I did not have the valves done, I did order new rocker arms, fulcrums and bridges. I purchased push rods also
Old Mar 5, 2020 | 10:33 AM
76sbo's Avatar
It will be a few weeks before it it ready to drive
jimmymtfan19
Dec 19, 2016 10:23 AM
Oct 2, 2016 08:09 PM
The Bug Man
Oct 25, 2013 08:37 AM
agtw31
Jun 4, 2009 08:35 AM
