Linkage and carb question
Alright so after figuring out that my throttle linkage was way off causing my passing gear not to
activate, the car is running better but still not perfect. My question is how do i properly adjust the throttle and kickdown cable? The kickdown is at full tension at open throttle now.Here is the setup of the throttle cable and kickdown cable going to a 200r4 and the engine is a 350 in a Oldsmobile cutlass s. The car was running perfect before the carb was pulled off and I’m thinking things weren’t put back together correctly because it felt like a whole different car befythe carb was messed with. The car had been sitting for a few years and does smell like its running rich and is blowing white smoke at high idle. Also can anyone help me identify this carb? I’d like to know how to adjust the idle and the two screws in the front of the carb, This is my first Oldsmobile and the oldest car I’ve owned since my 87 Chevy pickup with tbi.
Being an Eldelbrock carb is the first issue, the tune is probably way off and they have issues. You need the proper TV valve(kick down) cable bracket for the correct pull rate and make sure you are getting full throttle as well, pushing the pedal.
2. How would I know if I have the correct bracket for the linkage?
3. Is there any information out there on how to tune my specific carb?
1.The 200r4 needs the TV cable correctly adjusted or it will wreck the trans.
2. the throttle cable bracket looks like a homemade unit and the TV cable bracket set up needs to work w the trans
3.if you goto edlebrocks site you can download the manual for your carb
Start by throwing away that POS cable bracket. What a turd. Get the bracket from a 1980s Olds 307 that bolts to the rear two carb bolts. That bracket will accommodate both the throttle and TV cable and will actually align them with the throttle arm instead of the angle pull you have now.
Anyone on here know where I can find that bracket off a 80s 307 and my tv cable is frayed at the carb so I’ll want to replace that as well, anyone have recommendations?
olds 307 and 403
September 21st, 2017 08:42 PM
