Roller set-up
#42
Yes the 90 degree angles cast ears on lower left and right corners besides the easily noticed 7.5 cover is shorter than it is wide but the 8.5 cover is basically round height and width similar. Look under a S10 and see the 7.5 for reference
#43
should i take the drive shaft as well or get mine cut to length?.. Thinking about it, i think i should get the driveshaft lol. Probably get it balanced and everything.
#44
8.5 appearance , general round appearance https://www.chevydiy.com/wp-content/.../2015/05/6.jpg
#45
7.5 appearance (note shorter and wider besides smaller and no prominent lower corner ears )
http://www.hotrodders.com/forum/atta...id=39880&stc=1
#47
nice! I really appreciate this man. Im starting a new job which allows me to save money for my car and school. And guves me time to work on my car. I appreciate the info you guys. I really do
#50
If your asking about roller lifters, it's all the same. Roller rockers, not that much different either. The only slight disadvantage of alum durability wise is if your over-heating, they warp much easier but being alum you can run about 1/2 point higher compression with the same compression ratio due to heat dissipating quicker. I can go on on other advantages but I"m sure you would do some research. I believe edelbrock are only available in 400-455, not small block but can be modified to use on 350 or 403
Stevec
February 8th, 2015 01:25 PM
JRubino
December 30th, 2013 10:16 AM
