Roller set-up
Old February 5th, 2018, 08:54 PM
  #41
Out of Line, Everytime😉
olds 307 and 403's Avatar
Thin fangs, it is a 7.5", triangular ears are a 8.5". The 8.5" drive shaft is also 1" shorter.
olds 307 and 403 is offline
Old February 6th, 2018, 05:02 AM
  #42
GEARMAN69's Avatar
Yes the 90 degree angles cast ears on lower left and right corners besides the easily noticed 7.5 cover is shorter than it is wide but the 8.5 cover is basically round height and width similar. Look under a S10 and see the 7.5 for reference
GEARMAN69 is offline
Old February 6th, 2018, 05:18 PM
  #43
Copper Nine Eight's Avatar
should i take the drive shaft as well or get mine cut to length?.. Thinking about it, i think i should get the driveshaft lol. Probably get it balanced and everything.
Copper Nine Eight is offline
Old February 7th, 2018, 09:19 AM
  #44
GEARMAN69's Avatar
8.5 appearance , general round appearance https://www.chevydiy.com/wp-content/.../2015/05/6.jpg
Old February 7th, 2018, 09:20 AM
  #45
GEARMAN69's Avatar
7.5 appearance (note shorter and wider besides smaller and no prominent lower corner ears )
http://www.hotrodders.com/forum/atta...id=39880&stc=1
Old February 7th, 2018, 09:22 AM
  #46
GEARMAN69's Avatar
Besides just pull a tape measure vertical to 8.5 inch and see if it fits well between top and bottom bolts or not if these pics are not enough
Old February 7th, 2018, 02:41 PM
  #47
nice! I really appreciate this man. Im starting a new job which allows me to save money for my car and school. And guves me time to work on my car. I appreciate the info you guys. I really do
Old February 8th, 2018, 01:54 AM
  #48
ph_ckstick1
midnightleadfoot's Avatar
Whoith makith this stroker 350 olds kit?
midnightleadfoot is offline
Old February 8th, 2018, 02:09 AM
  #49
Inline's Avatar
Cutlassefi is selling it. Contact him. IMO his price is really fair for what you get.
Inline is offline
Old November 24th, 2022, 01:27 PM
  #50
James Windsor's Avatar
Originally Posted by 1970greensupreme
If your asking about roller lifters, it's all the same. Roller rockers, not that much different either. The only slight disadvantage of alum durability wise is if your over-heating, they warp much easier but being alum you can run about 1/2 point higher compression with the same compression ratio due to heat dissipating quicker. I can go on on other advantages but I"m sure you would do some research. I believe edelbrock are only available in 400-455, not small block but can be modified to use on 350 or 403
the edelbrock heads are big block heads! Valves are to big and the port’s are too big kills bottom end power!!!
James Windsor is offline
Stevec
February 8th, 2015 01:25 PM
Stevec
February 16th, 2014 04:02 AM
JRubino
December 30th, 2013 10:16 AM
Redog
August 14th, 2008 06:56 PM
Quick Reply: Roller set-up
