Fuel problem
Old Jan 10, 2018 | 08:52 AM
Amarion58's Avatar
Fuel problem
I have a 83 Buick Electra with a 307. It runs fine until after about 30 minutes of driving and just die. I can pour gas in the carb and it starts and die but if I wait a couple hours it starts back up fine and ready to drive. I replaced the fuel pump(mechanical) and filter but it is still doing the same thing. What else can cause this.
Old Jan 10, 2018 | 09:06 AM
Engines need air, fuel, and a properly timed spark to run. Air is usually a given, you must determine if its getting fuel and spark as the first step.
Old Jan 10, 2018 | 09:24 AM
TripDeuces's Avatar
Sounds like a hot ignition problem to me
Old Jan 10, 2018 | 10:22 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I don't think ignition since he can pour gas in the carb and it starts and dies.
Old Jan 10, 2018 | 11:27 AM
shiftbyear's Avatar
Could be the sock filter in the gas tank or the rubber fuel line connecters from the fuel pump back to the tank, 35 years is asking a lot from factory parts. Good luck, let us know what you find. Interesting post.
330jetstar
Sep 12, 2017 03:42 AM
jcs933
Sep 12, 2009 05:56 PM
glord
Jul 21, 2009 11:23 PM
ride
Sep 1, 2006 07:07 AM
starchildace
Mar 13, 2006 02:47 PM
