New 350 build
#42
Update;
Short block is together with the new Mahle pistons. I went with the 4.100 after a boring from std. Compression is 9.4:1.
Cam is Erson TQ40 on a 108 (I wanted a little more "attitude").
Heads are 7a's with 2.00/1.62 valves, crossovers filled and dividers welded. Intake will be a regular Performer first, then an RPM. Carb is a QF 750 Slayer for both.
Should be going to the dyno the week of the 19th. I'll keep you all posted.
#44
What oil pan are using? It will be nice to see my Performer on something that actually makes decent horsepower.
#46
Stock pan with a stock pump and the purple spring.
Main bearing clearance is about .0022-.0024, rods are .0025-.0027.
#47
I moved the high performance discussion to this thread so we don't hijack Marks.
https://classicoldsmobile.com/forums...rformance.html
#48
Cam change;
Going from the Erson TQ40 to a Lunati Hyd roller with similar specs, 218/226@.050, .502/.512 lift on a 112lsa.
You guys know I prefer rollers over flat tappets for just about everything. Decided to put this build further into the 21st century.
Thanks.
Thanks.
#49
Resonate TQ 40
Cam change;
Thanks.
Thanks.
#50
#52
#54
#55
#56
Here's the link for this build in the "for sale" section. Thanks for all the feedback gentlemen.
https://classicoldsmobile.com/forums...ml#post1075559
I can do a mix of the options given if someone is interested early enough.
#64
The new Mahle piston, 9.5:1.
Cleaned up 7a heads with 2.00/1.62 valves.
Erson TQ40’on a 108lsa.
Performer RPM intake and 750 Slayer carb
Chinese HEI
1.6 full roller rockers
Flowtech 1 3/4 headers blowing thru Magnaflow 2.5” mufflers
wildwillie1981
April 24th, 2013 04:19 PM
