New 350 build
Old Dec 24, 2017 | 06:46 AM
  #41
cutlassefi's Avatar
Yes most likely in the low to mid 6K range, carb to pan.
Old Feb 11, 2018 | 06:53 AM
  #42
cutlassefi's Avatar
Update;
Short block is together with the new Mahle pistons. I went with the 4.100 after a boring from std. Compression is 9.4:1.
Cam is Erson TQ40 on a 108 (I wanted a little more "attitude").
Heads are 7a's with 2.00/1.62 valves, crossovers filled and dividers welded. Intake will be a regular Performer first, then an RPM. Carb is a QF 750 Slayer for both.
Should be going to the dyno the week of the 19th. I'll keep you all posted.
Old Feb 11, 2018 | 07:00 AM
  #43
cutlassefi's Avatar
Pics didn't attach for some reason at first.
Old Feb 11, 2018 | 09:50 AM
  #44
olds 307 and 403's Avatar
Out of Line, Everytime😉
What oil pan are using? It will be nice to see my Performer on something that actually makes decent horsepower.
Old Feb 11, 2018 | 09:56 AM
  #45
RetroRanger's Avatar
72 Olds CS
Coming along nicely interested in seeing the performer and rpms results. Will you need to make carb adjustments for each manifold?
Old Feb 11, 2018 | 10:54 AM
  #46
cutlassefi's Avatar
We'll see but I would think yes. After that it gets a Holley Sniper EFI.
Stock pan with a stock pump and the purple spring.
Main bearing clearance is about .0022-.0024, rods are .0025-.0027.
Old Feb 11, 2018 | 06:39 PM
  #47
I moved the high performance discussion to this thread so we don't hijack Marks.
https://classicoldsmobile.com/forums...rformance.html
Old Feb 14, 2018 | 12:17 PM
  #48
cutlassefi's Avatar
Cam change;
Going from the Erson TQ40 to a Lunati Hyd roller with similar specs, 218/226@.050, .502/.512 lift on a 112lsa.
You guys know I prefer rollers over flat tappets for just about everything. Decided to put this build further into the 21st century.
Thanks.
Old Feb 14, 2018 | 02:40 PM
  #49
oldsmobiledave's Avatar
Resonate TQ 40
Cam change;
Thanks.
Did you run the engine with that cam or not?
Old Feb 14, 2018 | 03:12 PM
  #50
cutlassefi's Avatar
Nope, never got that far. Didn’t want to go thru the hassle of breaking in that cam then changing it along with the valve springs and pushrods. I’m all about trying to do things just once.
Old Feb 14, 2018 | 04:32 PM
  #51
Darn, I was wanting to see what hp the TQ40 put out. I am sure there is some power gained with the roller cam over the flat.
Old Feb 14, 2018 | 05:18 PM
  #52
cutlassefi's Avatar
Yeah my guess would be 10-15.
Cams have about the same @.050, just a little difference in total off the seat time.
Old Feb 14, 2018 | 08:07 PM
  #53
Oldcoyote's Avatar
But the 108 would have sounded so good .
Old Feb 15, 2018 | 04:48 AM
  #54
cutlassefi's Avatar
Agreed. Nothing is carved in stone yet though. It’ll ultimately depend on who’s interested in this build upon or before completion. We’ll see.
Old Feb 15, 2018 | 07:54 AM
  #55
Completely understand, you can't just do this build and Dyno session out of generosity.
Old Feb 16, 2018 | 01:17 PM
  #56
cutlassefi's Avatar
Here's the link for this build in the "for sale" section. Thanks for all the feedback gentlemen.
https://classicoldsmobile.com/forums...ml#post1075559
I can do a mix of the options given if someone is interested early enough.
Old Apr 20, 2018 | 08:10 AM
  #57
Results
Mark
Did you complete this SBO yet?
Old Apr 20, 2018 | 12:00 PM
  #58
cutlassefi's Avatar
Mark
Yes, it made 422/445 corrected hp and tq.
Old Apr 20, 2018 | 06:33 PM
  #59
BOP_Craig's Avatar
Impressive! Which intake and where those numbers with the carb or FI?
Old Apr 21, 2018 | 04:42 AM
  #60
cutlassefi's Avatar
Both, they were within a few hp of each other.
Old Apr 21, 2018 | 05:28 AM
  #61
Post the Dyno sheets and what all was used when you have time. Very nice numbers.
Old Apr 21, 2018 | 03:24 PM
  #62
cutlassefi's Avatar
And it was an RPM intake, sorry.
Old Apr 21, 2018 | 03:35 PM
  #63
Dave26's Avatar
Can’t wait to drop it in, sit behind it, and let it rip!!
Old Apr 21, 2018 | 04:17 PM
  #64
cutlassefi's Avatar
The new Mahle piston, 9.5:1.
Cleaned up 7a heads with 2.00/1.62 valves.
Erson TQ40’on a 108lsa.
Performer RPM intake and 750 Slayer carb
Chinese HEI
1.6 full roller rockers
Flowtech 1 3/4 headers blowing thru Magnaflow 2.5” mufflers
agreen316
Dec 21, 2013 06:27 AM
wildwillie1981
Apr 24, 2013 04:19 PM
dschallock
Apr 25, 2011 03:38 PM
J-(Chicago)
Mar 5, 2008 02:07 AM
69 442 protour
Dec 9, 2006 09:25 PM
