no oil coming thru push rods
Old Mar 17, 2009 | 06:20 AM
olds4life's Avatar
hey olds nation. what would cause oil not to flow thru the push rods up to the rocker arms. the 2,3 and 4 rockers aren't getting oil up to them. i checked the push rods and the are not clogged up. could it be the lifters. could this cause it to make a tapping noise. thanks
Old Mar 17, 2009 | 09:18 AM
Yes and yes
Old Mar 21, 2009 | 04:45 PM
Warhead's Avatar
See lifter tick in Big Block section.
Did you blow compressed air through them?
Rarely does the lifter itself do this, it's usually particles (debris), or heat that gums up the works.
Or lost oil pressure (oil level/oil pump/drive).
Jim
65cutty
Sep 8, 2010 02:22 AM
defiant1
Mar 6, 2010 07:00 PM
Atdog
Feb 14, 2009 06:51 AM
MY71CUTLASS
Oct 4, 2007 12:21 PM
Pinner
May 31, 2007 12:26 PM
