1964 330 Cutlass camshaft install?
Hello Everyone, just reaching out to the forum here to catch a few opinions and best way to go about removing timing cover/dropping oil pan,For camshaft/timing chain set install. The only questions i have is what everyone is doing to get oil pan sealed back up without removing entire pan? Can you remove front timing chain cover without removing any oil pan bolts first? Just looking for opinions on the removal and install of timing cover/oil pan procedures and getting everything sealed back up when doing a cam swap.Thanks everyone
Dumb question...but before you start..do you have the right cam? As in, 39 or 45 degree bank angle?
Yes, you CAN, but getting that thing to seal back up is kind of a pain considering it's getting sealing pressure from the lip of the pan. Sucks, but probably best to pull the pan and replace the pan gasket after the timing cover is reinstalled. Otherwise you're sitting there prying away to get the timing chain cover off and then have to squeeze that bottom rubber gasket in
I have replaced the cam without removing the oil pan. I could not get the lower edge of the timing cover back on due to the seal "wings" and it being too thick (normally it is compressed by the oil pan when op is placed on top of it then bolted down), so I trimmed the seal and used RTV to ensure a good seal between it and the pan. The RTV also acted as a lubricant to help force the seal over the oil pan leading edge.
This is not the optimal method but it worked for me many years ago.
I think I loosened some of the oil pan bolts (this was nearly 20 years ago), but the oil pan didn't budge so I trimmed the timing cover rubber seal so that I could jam it in. Took several tries, with trimming a bit, trying to stuff it in, then trimming a bit more until it squeezed in there. I had to use the larger timing cover bolts that screw into the block to pull it in.
[QUOTE=Fun71;1004881]I think I loosened some of the oil pan bolts (this was nearly 20 years ago), but the oil pan didn't budge so I trimmed the timing cover rubber seal so that I could jam it in. Took several tries, with trimming a bit, trying to stuff it in, then trimming a bit more until it squeezed in there. I had to use the larger timing cover bolts that screw into the block to pull it in.[/QUOTE
Thanks again for all the advise Fun71, much appreciated, i hope all goes smoothly this week with the the rest of the project,and ill report back! Thanks
