Light 350 pistons
Old November 27th, 2016, 06:53 AM
brownbomber77's Avatar
Light 350 pistons
Tried google and the search function and couldn't find an answer. Good light pistons for 350s. I know the Speed Pro forged ones are an old heavy design...what other options are there.
thanks
brownbomber77 is offline
Old November 27th, 2016, 07:24 AM
80 Rocket's Avatar
CP Pistons, Bill Trovato helped design them
80 Rocket is offline
Old November 27th, 2016, 07:44 AM
oldsmobiledave's Avatar
fyi
http://www.btrperformance.com/products.html
pistons & other treasures in the link
oldsmobiledave is offline
Old November 27th, 2016, 08:00 AM
Mikey_mick's Avatar
https://m.summitracing.com/parts/dms-6020x-4100
Anybody heard anything about these pistons?
The only CP carillo pistons I could find were in goofy diameters like 4.065
Mikey_mick is offline
Old November 27th, 2016, 08:40 AM
cutlassefi's Avatar
I'm working with DSS to do the same in multiple sizes. I'll know for sure once I meet with them at the PRI.
cutlassefi is offline
Old November 28th, 2016, 06:32 PM
Chevy budget Olds powered
coppercutlass's Avatar
i was told years ago you can have the speed pros lightened. the cost was about 150. Dont know how true that is but thats what i was told a long time ago.
coppercutlass is offline
Old November 28th, 2016, 07:28 PM
Four Hundred Forty Two's Avatar
Mark, I thought you were a big fan of Racetec/Autotec stuff, are they not making as good of stuff, is it just price difference.
Also was curious if there was a down side to the smaller ring packages for combo, track & street.
Four Hundred Forty Two is offline
Old November 29th, 2016, 02:42 AM
cutlassefi's Avatar
I'm still a fan of the Racetec stuff but DSS may be willing to do a shelf stock piston in various sizes. It would still sport the better ring pack but be available much quicker than a true custom piston. Same material as well, could be a win-win.
Old November 29th, 2016, 07:02 AM
Run to Rund's Avatar
Since the 1970s I have been using 350 Chev pistons with floating pins, and bush the rods down to .927". If you use race pistons, it saves about 1/2 pound per assembly, but you do have to deck the block .055" more because their compression height is that much lower than Olds. Now I am using Mahle stuff.
Run to Rund is offline
Old November 29th, 2016, 12:44 PM
Ryan 1969 Chevelle SS396's Avatar
Based on some awesome feedback here on ClassicOldsmobile.com I stepped up a little and decided on Forged Aluminum 4032 Small Block Chevy 400 Pistons Wiseco Pro Tru 4.125 OD (0.068" overbore) compression height 1.425" with 1/16, 1/16, 3/16 rings, and 6.200" long 5140 Eagle I beam rods for Small block Chevy (have to grind the rod journals down to 2.100" vs 2.125 stock) The 1.425" CH and 6.2" rod raises the piston 0.010" which helps increase my compression without milling a lot off the heads and affecting valve train geometry.
This set up in theory is positive in a lot of ways:
piston weight
pin weight
floating pin
thin modern ring design (reduced friction, improved compression sealing)
I beam rod vs stock forged rod, (improved strength, reliability)
Forged piston vs stock cast, (improved strength, reliability)
Increased displacement 362ci, vs 350ci (more boom boom)
improved rod/stroke ratio (internet says this is good?)
improved bore/stroke ratio (Revs faster?)
CH and rod length combo raises piston 0.010" (less milling of block or heads)
minimal 5cc valve relief dish (keeps compression high)
This was not a huge cost increase as the SBC parts are low price/high volume.
Ryan
Ryan 1969 Chevelle SS396 is offline
Old November 29th, 2016, 02:48 PM
cutlassefi's Avatar
piston weight
pin weight
floating pin
thin modern ring design (reduced friction, improved compression sealing) Newer designs are even thinner.
I beam rod vs stock forged rod, (improved strength, reliability) True
Forged piston vs stock cast, (improved strength, reliability) True
improved rod/stroke ratio (internet says this is good?) Up to a point
improved bore/stroke ratio (Revs faster?) That's not really the deciding factor on rev speeds.
CH and rod length combo raises piston 0.010" (less milling of block or heads) Depends on the dish or valve reliefs in the piston used, not an automatic
minimal 5cc valve relief dish (keeps compression high) See above
This was not a huge cost increase as the SBC parts are low price/high volume. True
Ryan
But a few inaccuracies here. And did you check the clearance on the wrist pin vs the piston boss? Sometimes you have to grind a little off one side of the small end of the rod because Chevy rods are offset, Olds are centered.
Old November 29th, 2016, 03:43 PM
Thanks Mark,
Your help has been keeping me moving ahead step by step!!
I am a rookie and don't understand the pin concern, but need to know so I can verify with the engine shop.
Please continue to chime in more.
Hope this isn't thread stealing?
Ryan
PS: The rings I selected are the minimum thickness allowed in PSMCDR rules, no metric rings:-) otherwise I would have. 0.070" overbite max as well.
Old November 29th, 2016, 03:45 PM
Overbite is over bore:-)
Also measuring and going for a real 9.9 to 1 static compression.
Ryan
Old December 1st, 2016, 07:18 AM
80 Rocket's Avatar
I have a set of TRWs that have been substantially lightened at my shop. They were the ones in the Mashers motor that had .014" piston to wall clearance. Needless to say the skirts collapsed.
jslabotsky
March 23rd, 2011 08:20 AM
66-3X2 442
January 19th, 2011 12:14 PM
michael hilsabeck
October 18th, 2010 02:42 PM
77omega
May 9th, 2008 07:25 PM
Big J
April 21st, 2007 08:31 PM
Quick Reply: Light 350 pistons
