help identifying these parts
Old Feb 28, 2016 | 05:04 PM
denf221's Avatar
Hey there I have a 72 supreme with stock 350 was under hood today just evaluating things, saw these two parts and have a few questions. The first part is on the passenger side valve cover with hose that runs up under the air cleaner, cover. What is this, oil breather? It is shiny now because I wiped it off but it was completely covered with what looked like oil, I assume this is not good, time to replace? The second part looks like something emissions related, it is the cylindrical piece in the pic it is located in front of the accelerator spring and it looks like it should have a hose attached to front but it is broken, what is this? should It be re-attached if so to what? Thank you.....I tried to attach pics hope they came through
Old Feb 28, 2016 | 05:06 PM
m371961's Avatar
Get a factory Chassis Service manual.
Old Feb 28, 2016 | 09:18 PM
Ancient Iron's Avatar
1st pic is a crankcase breather 2nd is a carburetor dashpot
Old Feb 29, 2016 | 06:17 AM
^^^This.
To add to the description, the breather on the valve cover connects to a filter inside the air cleaner housing. You can replace that filter if needed. The breather on the valve cover simply has a screen in it and usually doesn't require replacement.
The dashpot does not have a hose connection. It is simply a "shock absorber" so the throttle blades don't slam shut too quickly if you release the throttle rapidly.
Old Feb 29, 2016 | 08:26 PM
jaunty75's Avatar
Out of curiosity, what on this thing does it look like the hose should be attached TO?
Old Mar 2, 2016 | 06:59 AM
denf221's Avatar
Help identifying parts
Looks like little post on very end
Old Mar 2, 2016 | 07:07 AM
Are you talking about the plastic part closest to the carb?
If so, no, that's simply the guide for the (missing) metal plunger that is supposed to be contacting the throttle arm on the carb.
Old Mar 5, 2016 | 06:29 PM
denf221's Avatar
Bey thanks bud I knew something was broken from it just didnt know what thanks again
67442nut
Jan 25, 2025 12:44 PM
16Victor
Jan 10, 2016 10:53 AM
junkyard junky
Nov 29, 2015 07:12 AM
veltboy618
Oct 23, 2010 08:53 AM
alan69delta88
Jul 9, 2006 05:16 PM
