Yet another dumb question...
Old August 19th, 2011 | 05:19 PM
cutlass xombie's Avatar
Ok I was checking fluids and things and when I pulled the breather out of the valve cover to check it there was something rattling around inside it.
Now I haven't seen a breather in some time and don't quite remember what exactly is supposed to be inside. some kind of filter if I remember correctly.
Now do I replace the whole thing or does it open up and a filter is inserted inside or what? and would this cause any problems with that piece rattling around inside it...I'm thinking it may block the hole to the breather.
Also were these the same colour as the engine?
Thanks,
Rob
and don't worry I'm sure I will have some more dumb questions coming
Old August 19th, 2011 | 09:01 PM
BIGJERR's Avatar
I bleed Oldsmobile
A junk yard replacment is in order or they come in chrome aftermarket.....apprently the element inside of yours is bad.......As I remember its like a piece of foam..........been many years since I dealt with stock parts tho.......
Old August 20th, 2011 | 04:49 AM
Thanks BigJerr...that's what I thought....do you think it would run rough if the breather was blocked by whatever is inside it?
Old August 20th, 2011 | 05:38 AM
Nope - shouldn't affect running at all.
If something is rattling around, it's probably letting too much in (not filtering), rather than clogged. You can tell by blowing through it.
Old August 20th, 2011 | 08:01 AM
Great thanks MD....now I just have to find one
Any ideas?
67BB
Suspension & Handling
March 1st, 2013 07:49 AM
kitfoxdave
January 6th, 2013 07:16 PM
Frank3
October 1st, 2012 08:28 PM
coppercutlass
March 20th, 2012 05:14 AM
nonhog
January 23rd, 2009 02:09 PM
