Yet another dumb question...
Old Aug 19, 2011 | 04:19 PM
cutlass xombie's Avatar
Ok I was checking fluids and things and when I pulled the breather out of the valve cover to check it there was something rattling around inside it.
Now I haven't seen a breather in some time and don't quite remember what exactly is supposed to be inside. some kind of filter if I remember correctly.
Now do I replace the whole thing or does it open up and a filter is inserted inside or what? and would this cause any problems with that piece rattling around inside it...I'm thinking it may block the hole to the breather.
Also were these the same colour as the engine?
Thanks,
Rob
and don't worry I'm sure I will have some more dumb questions coming
Old Aug 19, 2011 | 08:01 PM
BIGJERR's Avatar
I bleed Oldsmobile
A junk yard replacment is in order or they come in chrome aftermarket.....apprently the element inside of yours is bad.......As I remember its like a piece of foam..........been many years since I dealt with stock parts tho.......
Old Aug 20, 2011 | 03:49 AM
Thanks BigJerr...that's what I thought....do you think it would run rough if the breather was blocked by whatever is inside it?
Old Aug 20, 2011 | 04:38 AM
Nope - shouldn't affect running at all.
If something is rattling around, it's probably letting too much in (not filtering), rather than clogged. You can tell by blowing through it.
Old Aug 20, 2011 | 07:01 AM
Great thanks MD....now I just have to find one
Any ideas?
67BB
Suspension & Handling
Mar 1, 2013 06:49 AM
kitfoxdave
Jan 6, 2013 06:16 PM
Frank3
Oct 1, 2012 07:28 PM
coppercutlass
Mar 20, 2012 04:14 AM
nonhog
Jan 23, 2009 01:09 PM
