Where is oil pressure switch?
Old Apr 7, 2010 | 06:40 PM
jtriggy's Avatar
Ok boys, stupid question...
Where is the oil pressure switch on my 1970 Cutlass Supreme 350?
Restomod underway! Exciting!
Thanks,
James
Old Apr 8, 2010 | 03:22 AM
Yellowstatue's Avatar
Right behind the water pump, on the drivers side,on the little shelf and there should be a dark blue wire dangling off the top...it stands up vertically, skinny where it threads into the block and fat at the top-about 1 1/8" takes a special socket to un-screw unless it is junk then vice-grips work great...
Old Apr 8, 2010 | 06:47 AM
jtriggy's Avatar
Hmmmm
I could have sworn that was the water temp switch. Right now I have no wire reference as the engine was recently totally rebuilt. My fear is that the machinist removed the oil sensor switch and put a bolt in its place in order to seal the hole while he worked on it.
Old Apr 8, 2010 | 07:28 AM
Lady72nRob71's Avatar
See here for location:
https://classicoldsmobile.com/forums...tml#post164895
70 should be the same as 72.
Old Apr 8, 2010 | 07:45 AM
Oldsguy's Avatar
Past Administrator
They are all in the same location.
foreverolds
Dec 1, 2012 07:07 PM
Redog
Jul 20, 2011 04:10 PM
christine fury
Apr 8, 2010 09:27 AM
DAN76
Jan 1, 2010 03:13 PM
