When I crank my car for the first time it idles high - 72 Cutlass S (350 Rocket)
Old Aug 28, 2016 | 12:01 PM
LJ72Cut's Avatar
I have a 1972 Olds Cutlass S with a 350 Rocket and I was just curious as to why when I crank the car for the first time it idles/runs loud and if I wait for a few minutes and step on the gas it idles down and runs like it normally sounds. Also, I notice that I have a gas smell in my garage sometimes but I don't see any leaks anywhere. I usually have to open my garage doors to let the fumes out before I start working on the car.
Old Aug 28, 2016 | 12:26 PM
m371961's Avatar
The idle is typical for a carburetor car. The high idle is needed when the choke is closed and engine is cold.
Old Aug 28, 2016 | 12:54 PM
jpc647's Avatar
All of that sounds typical.
The idle is working as it should, it sounds.
And the fumes are normal. Carbs aren't closed systems, so the gas does evaporate, hence the smell.
Old Aug 28, 2016 | 01:03 PM
LJ72Cut's Avatar
m371961 thank you. Makes sense...I was always curious about the noise. I knww pressing the pedal would make it sound like normal just didn't know the logic behind the process. Thank you again.
Old Aug 28, 2016 | 01:04 PM
LJ72Cut's Avatar
jpc647,
Thank you. I was thinking maybe something was wrong with my gas tank and some how fumes were getting out from a seal. I had thought about dropping it and checking it out but thank you for the explanation that makes sense.
Old Aug 28, 2016 | 01:32 PM
m371961's Avatar
Your first carburetor car? Generally to start, you hit the go pedal once to the floor, let it return, then engage starter. As it warms, you hit the pedal and the idle lowers. At least when the choke is adjusted and working correctly. The higher idle speed is adjustable if needed.
You do have a chassis service manual that explains all this, right? If not, you should.
Old Aug 29, 2016 | 08:24 AM
jpc647's Avatar
posted in wrong thread.
Old Aug 31, 2016 | 05:42 PM
LJ72Cut's Avatar
Should I let it idle high for a certain time? I normally just hit the gas after a minute or two.
Old Aug 31, 2016 | 07:22 PM
Idle time depends upon the ambient temp. In cold weather it will take longer, in hot weather it will not take as long.
truerollers
Feb 28, 2017 01:00 PM
kevin.horton
Jun 15, 2011 04:05 PM
Stevec
Jun 7, 2011 06:11 PM
rgass
Feb 19, 2011 08:13 PM
arall
Oct 15, 2006 08:54 AM
