What type of puller for the crank gear?
Old Mar 13, 2012 | 03:00 PM
Nasty455's Avatar
XCELERATIONRULES!
Need to pull off the crank gear to install the new timing set.
I'm guessing I need the puller with the three claw type arms?
Thanks.
Old Mar 13, 2012 | 04:22 PM
442Harv's Avatar
That will work.
Old Mar 13, 2012 | 07:22 PM
Octania's Avatar
split it with a beasty chisel at the keyway and any screwdriver or pry bar will take it right off...
Old Mar 13, 2012 | 07:54 PM
Rickman48's Avatar
X2 on the chisel!!
Old Mar 13, 2012 | 10:01 PM
SBORule's Avatar
three claw type should do it.
Old Mar 14, 2012 | 02:07 PM
Nasty455's Avatar
XCELERATIONRULES!
I'm always looking for an excuse to buy another useful tool.
I learned early that using the right tool saves time, money, and headaches.
I'd like to save the gear and key way if possible.
Thanks guys.
Old Mar 15, 2012 | 11:20 PM
cjsdad's Avatar
Don't forget the BFH if you need to employ this option!
File Type: gif
File Type: gif
Old May 3, 2013 | 08:27 PM
Octania's Avatar
Thanks guys.
You don't own a chisel and hammer already?
You don't work on Fords much, eh?
You are right, the right tool [BFH and chisel] saves time, money, and headaches. There is no reason to "save" a worn out timing gear. What are you going to do, replace just part of the timing set?? Of core snot.
Old May 3, 2013 | 09:17 PM
rjohnson442's Avatar
Mr. Johnson
Ha and I always felt bad using the claw end of a framing hammer. never hurt a key yet
Old May 4, 2013 | 04:26 AM
ELY442's Avatar
I just did one recently and I used a craftsman pry bar and it came out pretty easy. Just pry 1 side at a time and when you have enough space to use a hammer just hit it out.
Bernhard
Nov 24, 2022 09:12 AM
L77F85
Drivetrain/Differentials
16
Nov 29, 2013 06:19 AM
Bernhard
Jan 6, 2013 09:27 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
The Stickman
Jun 3, 2009 09:34 AM
