What is...this hole?
Old Jul 23, 2011 | 08:31 PM
Redog's Avatar
Question What is...this hole?
Swapped the Moroso 20480 oil pan today and I found this port. It had the gasket going around it and the new gasket goes over it. It didn't go anywhere with the old pan on. I could see where it was blocked off by the old pan, but with the new pan, it's as blocked as the gasket blocks it in this pic.
What is it? It looks like an oil drain hole, but no return into the pan. Can I leave it unblocked without a problem (I doubt it)
Old Jul 24, 2011 | 09:21 AM
Redog's Avatar
Really? Nobody knows?
Old Jul 24, 2011 | 09:22 AM
It's a blind hole that's simply used to locate the block for machining on the assembly line. Ignore it.
Old Jul 24, 2011 | 09:27 AM
Redog's Avatar
OK Thanks Joe.
There was some crud in it so I cleaned it out a bit and the flathead didn't go in very far.
I ran out or the black RTV too so I had to finish the job with clear RTV. I put the black on the block and mostly on the top of the one side of the gasket, then I finished up with the clear. Will the clear be OK?
Old Jul 24, 2011 | 09:42 AM
It'll be black soon enough.
Old Jul 24, 2011 | 12:30 PM
Redog's Avatar
Hahaha
TheRuss
Sep 30, 2025 05:33 AM
RAMBOW
Aug 18, 2012 12:00 PM
MN71W30
Jun 28, 2009 12:03 PM
silverriff
Dec 4, 2008 01:51 PM
steve19
Nov 26, 2008 06:36 PM
