what cam for 330?
Old Jan 22, 2011 | 07:25 AM
64oldsguy's Avatar
what cam for 330?
I am replacing my cam and lifters in my 330 high comp., 4 bbl engine. It has 40,000 miles on it but #4 cyl. was chattering and found a worn lifter. I am wondering if I can go with a little bigger cam and keep the stock valve train. Any ideas?
1964 olds cutlass
Old Jan 22, 2011 | 08:43 AM
64Rocket's Avatar
You sure can. With out any other mods, I would only go only slightly more. I would say sonething in the 204/208 @.050 range. Also remember your engine is a 45* cam bank angle, so the cam will have to be speacial order. You might want to get valve springs also. Can't go very much bigger for your converter is stock.
Gene
Old Jan 23, 2011 | 08:39 AM
What if you have a sw pitch converter, would that not allow for a bigger cam?
Old Jan 23, 2011 | 04:35 PM
cutlassefi's Avatar
I can grind you anything you want on a 45 degree 330.
Old Jan 23, 2011 | 06:31 PM
64oldsguy's Avatar
thanks for the response 64rocket. I looked at Mondello for cam/lifter/springs, but they don't specify a cba of 45* or 39* for their cams. There also seems to be some inconsistency on the cba of the 330's in every forum.
Old Jan 23, 2011 | 06:57 PM
cutlassefi's Avatar
All 330's are 45 degree to my knowledge. We can do whatever is right for your application.
Old Jan 24, 2011 | 10:38 AM
Run to Rund's Avatar
Various companies can do 45 deg. cams on a custom basis. You engine should be 45 deg but you can verify that with two dowels, one in a left side and the other in a right side lifter bore, and check the angle between them. If the included angle is 90 deg. you have a 45 deg. angle; otherwise the angle is noticeably less than 90 and is a 39 deg. block.
Old Jan 27, 2011 | 03:15 PM
MnOlds's Avatar
ID/ Casting
Code Year(s) CID Number Notes
1 '64-'66 330 381917 45° cam bank angle.
1A 330 381917 45° cam bank angle.
2 '68-'76 350 381917
2 '68-'70 350 395558
3 '66-'67 330 394417 39° cam bank angle.
From 442.co* for what it's worth
Old Aug 7, 2011 | 07:34 AM
64oldsguy's Avatar
valvetrain
Gene
Old Aug 7, 2011 | 07:56 AM
64oldsguy's Avatar
valvetrain
Gene
Hey 64rocket, it's been awhile but still having some issues with my new cam. I'm running a comp cam, 224/230 @.050. It's for a 45* cba. 486/489 valve lift. I'm also running new valve springs 130/320 spring pressures. This is my second cam and lifter kit I've tried thinking that would fix the noise(every lifter making chatter). I'm just wondering if the noise could be from something else. I have the rocker arm shaft set up, are there limitations with that. Any info about that 330 motor with that rocker arm set up would be helpful.
67flamedcutlass
Dec 19, 2019 07:54 AM
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
jrblanke
Aug 7, 2011 08:19 AM
