W-31 Owners
W-31 Owners
W-31 owners. I'm looking for bone stock W-31 motors. I have built my motor as close to W-31 specs as is possible with todays components. I'm getting 10 inches of vacuum at idle. That seems lower than what I'd expect from a factory motor. I know 82* of overlap is considerable for 350 cubes, but it still seems like it should be closer to 14 inches. So to you stock W-31 owners, if you'd care to, could you throw a vacuum gauge on your motors and tell me what you are getting? Include how much flutter you're getting. A little, a lot, none.
Thanks a bunch.
Thanks a bunch.
I wish every true Oldsmobile fan could drive a factory W car. Completely different animals. I had a friend with a 70 W-30. Kind of a beater but man did that car run. Then one of my brother's had his W-31. That car pulled so strong.
I think that’s fairly accurate based on my experiences. My engine had 14-16” bouncy vacuum with the 217* cam and the power brakes were iffy. After much tuning I got it to a steady 16” vacuum and the brakes work very well, they seem the same as the factory setup that had around 20” vacuum.
