valve size
Old Dec 27, 2007 | 09:37 PM
olds1968's Avatar
member
valve size
hey guys i have #5 heads on my engine do you know what size the valves are?
Old Dec 28, 2007 | 09:57 AM
GoldOlds's Avatar
1.875" int. and 1.562" ex. I've got the same heads on my Cutlass. They're good heads that flow quite well. I consider the intake valve diamater a bit on the small side, but apparently it doesn't really matter unless you're building some 500+ hp monster.
- GoldOlds
Old Dec 28, 2007 | 05:37 PM
olds1968's Avatar
member
are those the only size that came in these heads?
Old Dec 28, 2007 | 07:18 PM
2blu442's Avatar
Valves
I believe the W31 had a 2.00" intake, not sure about the exhaust size. It makes sense that you could cut the valve seats out and install the larger valves. But the chances of finding a factory set of W31 heads is pretty low. John
Old Dec 29, 2007 | 09:12 AM
Correct. The #5 heads used on the 68-69 W-31 were cut for big-block sized 2.000 intakes and 1.625 exhausts. Pretty much any SBO heads can be cut for the same. The #5s do not have hardened seats, so cutting for larger valves is easy.
1970_442
Aug 11, 2018 07:50 AM
Mike H.
Brakes/Hydraulic Systems
Mar 7, 2013 10:48 AM
Wildcard
Dec 9, 2012 10:35 AM
jpc647
Oct 12, 2012 03:11 PM
JRios
Dec 13, 2010 11:13 PM
