valve keepers (locks)
Old Oct 15, 2010 | 01:34 PM
AnthonyH'79Delta88's Avatar
Are the stock olds keeper angles 7deg or 10deg?
Old Oct 15, 2010 | 02:25 PM
I believe they are 7 deg.
Old Oct 15, 2010 | 03:22 PM
Run to Rund's Avatar
definitely 7 degree
Old Oct 17, 2010 | 09:51 AM
Warhead's Avatar
The only factory 10 degree keeper I know of off the top of my head, was for a Buick engine. If you have a true Oldsmobile engine, like said above, they would be 7 degree keepers.
If you have a true Buick engine, it could be different.
The 10 degree keeper is like 2x thicker than the standard 7 degree, scrawney tiny, keeper. Hefty item, that many in the aftermarket like to use with monster valve spring pressure.
Jim
Old Oct 19, 2010 | 12:29 PM
Thanksyou, that helps alot. Im putting stiffer springs in with my bigger cam and got kinda confused.
pogo69
Mar 31, 2014 05:01 PM
Razorback1974
Mar 30, 2007 12:35 AM
jrbarrie83
Jul 4, 2006 09:16 AM
DonFrost
Oct 22, 2005 03:30 PM
