Valve covers-what do you think ?
Old Jan 16, 2008 | 05:36 PM
The_Jeremiah's Avatar
hey guys, im putting my engine together as we speak, im going to wire wheel my valve covers and repaint them. what im wondering, is what you guys have done with the hoses that run from each valve cover ?. this is a 69 350 so on the driver side i have one hose that runs to the back of the carb, which ill keep, however on the passenger side there is some sort of filter, and it runs into the air cleaner. im going use a chrome air cleaner instead of the stock one, so can i just put a breather air filter cap in that one and call it good ? or am i better off finding performance valve covers ? what do you think ? also have you guys developed any good ways of getting the valve cover grommets in and out ? because they are pretty tough. thanks
Old Jan 16, 2008 | 05:39 PM
I used a pair of channel lock pliers to take the grommets out of the valve covers. They should just slide in and out if you give them a little twist.
Old Jan 16, 2008 | 07:47 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I suggest that you keep the pcv valve.
The crankcase filter can be replaced with a simple press in MR. Gasket breather.
Old Jan 17, 2008 | 05:48 AM
Oldsguy's Avatar
Past Administrator
The hose to the intake/carb must have the pcv valve on it and the grommet associated with it because I haven't seen aftermarket ones that fit it well. The other hose to the air filter element housing can be replaced with a small filter element on the cover itself as J suggested. People do this often, especially if they replace the valve covers and air filter element housing with aftermarket stuff.
Old Jan 21, 2008 | 09:38 PM
Ok cool, ill definently get some good pictures up in a couple weeks when this thing is done. This things gonna look sweet. Thanks for all the input
Old Jan 24, 2008 | 12:11 PM
Redog's Avatar
I put a K&N filter in the other side. Works very well and looks cool
citcapp
Sep 11, 2019 11:02 AM
RAMBOW
Mar 20, 2017 06:58 PM
Blackpage
Nov 18, 2012 06:04 AM
pcard
May 15, 2011 07:49 AM
