Valve cover bolt snapped- how should i extract it?
Darn! I over torqued one of the valve cover bolts and it snapped off in the head. I tried to hammer in an extractor, to no avail. Any ideas?
Thanks!
Chris
Thanks!
Chris
Did it break off above the cylinder head or even with the head.?Can you get to it to center punch and drill the bolt ?If so, you should be able to hammer an extractor into the hole and back it out. You might try heating it with a small propane torch if necessary,being cautious that that the heat is held directly on the bolt. Good luck, Larry
I did pretty well to drill it out. I got a lot out then the bit broke inside the hole. Ugh. I can get a little bit of grip by putting the original bolt in the hole. If worse comes to worse should i trim the bolt and use it like that? I am able to get 3/16" of the bolt down into the hole... Would that be enough to secure the valve cover if i can get the bit/ bolt combo out?
As always, Thanks!
Chris
As always, Thanks!
Chris
From the picture, it appears that you might still center punch the center of the bolt then dril
with a 1/8" bit ,then a 3/16" and tap the ease out made for a 3/16" hole ,and maybe it will back out. If not,maybe the 3/16 " depth will work to hold that corner of the valve cover if it will tighten the valve cover enough to not leak.Its not like you would need to "torque it".
Larry
Larry
Oldcutlass unfortunately no. I was using what I think was a harder than steel bit because it was cutting through the bolt before it broke but none of the other bits could even make a dent in it. So I might have to go out and get a titanium set and try that.
Almond900
February 26th, 2016 02:56 AM
monzaz
September 11th, 2012 08:27 PM
RAMBOW
August 13th, 2012 05:29 PM
