vacuum lines
Old Mar 13, 2007 | 05:51 PM
terribleonexx88's Avatar
vacuum lines
these two lines coming off this are vacuum where do they hook up to? would these snipped vac lines cause hesitation?
Old Mar 13, 2007 | 06:38 PM
soocutlass's Avatar
these are not necassry to hook up. How it is used is when the temp of the motor goes up it allows for your vacuum advance to work, if the motor is not up to temp the ignition timing vacuum advance will not work. So it act as a vacuum switch based on temperature to open.
Old Mar 13, 2007 | 06:41 PM
soocutlass's Avatar
originally it look like to switch that is mounted in the intake not the air breather sorry.
Old Mar 13, 2007 | 07:53 PM
well the two rubber lines are snipped off and i can feel the vacuum so they were hooked up to something and i cant find what. im trying to figure out why my car hesitates from a stop and i notice those lines 2day and was wondering if that had any thing to do with it
Old Mar 14, 2007 | 04:57 AM
Oldsguy's Avatar
Past Administrator
If you have a vacumm leak because those lines are snipped off and not plugged that could cause your hesitation. I would plug the one from the vacumm source and find out where the other one goes and remove it. It seems that only one should have vacumm on it. Seems like what soocutlass said is right except it works on inlet air temperature instead of engine temperature. I suppose the best thing to do if your car is still completely stock is to replace the hoses onto the device and let it be. Your car is an '88 Cutlass right? There was lots of computer interaction with the engine timing by that time and unless you remove the whole thing and re-tune your engine to run without it you might be better off just to leave it all on.
Old Mar 14, 2007 | 12:58 PM
its a 78 cutlass
Old Mar 14, 2007 | 02:59 PM
soocutlass's Avatar
I would cap off both side of the sensor because if it is a temp switch which it looks like then it will open after it reach temp and the idle problem will come back.
Old Mar 15, 2007 | 02:26 AM
Jim's rare 80's Avatar
Jim's rare 80
Hi. I have an 80 Cutlass. The good is.. it's in pieces, being restored, and will be like new soon. The bad is.. It's in pieces, being restored, and I can't drive it right now. The other good is, I know this is a thermal switch to control the secondary choke pull off. It's fed off of your breather vacumn supply. If this is leaking air, it will cause hesitation, if you have a 4bbl carb, don't bypass it. Let us know engine and carb config', and we'll go from there. Jim
Old Mar 16, 2007 | 12:00 PM
its a 2bbl. does any one have pictures of there 260 2bbl i can look at because the vacuum diagram i looked at didnt help me. i took off the thermal thing altogether and it still hesitates. to get going i have to tap the gas and let off repetedly.
Markie
Oct 19, 2008 05:05 PM
StarfireFox62
Sep 25, 2008 01:29 PM
#1CutlassSupreme
May 14, 2008 04:28 PM
Chumley
Jan 3, 2007 06:00 AM
bbock
Jun 5, 2006 11:50 AM
