Vacuum leak found!
![Talking](https://classicoldsmobile.com/forums/images/icons/icon10.gif)
I've been trying to chase down a dieseling issue for a long time. Finally, I discovered a place that some may have overlooked; the connector to the Thermal Vacuum Valve on the air cleaner. The holes on rubber connector had stretched too far, causing a small leak and forcing the ILC plunger out. This one drove me nuts! Anyway, I plugged the connector since the preheater doesn't do me any good in the desert.
Everything is fine now, but I had to readjust the carb mixture. I ended up having to turn each idle mixture needle in (leaner) by 1.75 turns to get the dwell near 30. That's pretty significant. I'm willing to bet that will help my gas mileage, too! Just wanted to pass on a nugget of wisdom to anyone that's looking for vacuum leaks on their 307 beast!
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
Yes, 83 uses the CCC and electronic Q-jet.
My guess is he used a dwell meter hooked to the mixture control solenoid and adjusted mixture until solenoid was running at around 50% duty cycle.
There is a lead laying on top of the engine for this purpose and this is actually the way the FSM instructs.
So this is not ignition dwell...
Ohhhhhh... Not the points dwell angle, which is an angular measurement of duty cycle, but the actual duty cycle of the mixture solenoid as measured by a points dwell meter.
I see. Never mind.
I see. Never mind.
